C4 Ignition Key Problems
Old Jan 16, 2007 | 09:59 PM
RCTrucking's Avatar
RCTrucking
Default C4 Ignition Key Problems
My Ignition Key will not always turn to the lock position making it impossible to remove the key, Does anyone have any input on what may be causing the problem?
Old Jan 16, 2007 | 10:08 PM
GIMMESOME's Avatar
GIMMESOME
I don't know what year yours is,but I had problems with the switch not goinig into to accessory position,a little bit of WD squarted around th barrel of the cylinder solved it,you could try it.Could be a problem with the rack also.
Old Jan 16, 2007 | 10:12 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
I also sprayed a tiny amount of lubricant into the key cylinder which helped.
Gary
Old Jan 16, 2007 | 10:13 PM
RCTrucking's Avatar
RCTrucking
My C4 is a 1995
Old Jan 16, 2007 | 10:19 PM
RCTrucking's Avatar
RCTrucking
Thought about doing that but was concerned about contaminating the vats
Old Jan 17, 2007 | 07:28 AM
enventr's Avatar
enventr
If it has auto transmission,make sure the button is all the way up on the shifter-jiggle it around.If its not ,you wont be able to remove the key
Old Jan 17, 2007 | 07:33 AM
runner140*'s Avatar
runner140*
Try using a new key (vats). Sometimes keys get old and don't work anymore.
Old Jan 17, 2007 | 08:09 AM
Goldcylon's Avatar
Goldcylon
A little left and right action on the steering while trying to remove the key might work as well while your in park. Works for me. Goldcylon
Old Jan 17, 2007 | 11:35 AM
RCTrucking's Avatar
RCTrucking
The car only has 37,000 miles on it I wouldn't think wear would be the problem,by turning it on and off numerous time's when it occures it finally goe's to lock. I thought maybe someone else had experianced this and could direct me in the rite direction to correct it, any input is greatly app.
To C4 Ignition Key Problems
