gas guage
Old Jan 18, 2007 | 10:59 AM
ovrebo1's Avatar
ovrebo1
Default gas guage
i recently purchased a 92 vette. the gas gauge doesnt work so i was posting this to see if any one can give me a brief discription on how to take the sending unit out. thanks
Old Jan 18, 2007 | 11:02 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The sending unit is on a stem that includes the fuel pump; both are accessable easily through the top of the fuel tank:
-remove the fuel door
-remove the rubber boot
-remove the clamps on the three fuel lines
-open the electrical connector
-remove the ring of screws around the metal flange
-lift the fuel pump & sending unit from the tank
Old Jan 18, 2007 | 11:52 AM
ovrebo1's Avatar
ovrebo1
Default thanks
thanks
Old Jan 18, 2007 | 10:27 PM
Frizlefrak's Avatar
Frizlefrak
This should answer your fuel sending unit questions...
http://forums.corvetteforum.com/show....php?t=1574491
Old Jan 18, 2007 | 11:34 PM
65Z01's Avatar
65Z01
Now that's a "procedure", thanks...
Old Jan 19, 2007 | 02:26 AM
RRT vette's Avatar
RRT vette
The above should fix the problem.
Old Jan 22, 2007 | 10:56 AM
ovrebo1's Avatar
ovrebo1
thanks. as soon as the weather gets better ill get on that. lol i also have a ranger with a 5.0 in it and i put a bronco II tank in it and i cleaned the crap outa the sending unit before i put it in and the gauge still doesnt read lol, so ill have to do that resistance check when i take it out. so for the mean time. i have 2 vechices without gas gauges
Old Jan 22, 2007 | 07:17 PM
A. Reda's Avatar
A. Reda
5th Gear
I had the same problem with my 89 Vette. Got on the forum and Frizlefrak sent me the directions to remove the unit and make the repair. His instruction were right on the money and my fuel gauge now works. As he points out just be careful with the removal and cleaning. Great advise from forum members.
Old Jan 22, 2007 | 09:47 PM
gator79's Avatar
gator79
has anybody tried techron fuel additive on the C4 sender to clean it? I know it is recomended by Ford on some senders we are having problems with and it works. also it was a fix for some C5 sender problems.
Old Jan 31, 2007 | 09:50 PM
chief253's Avatar
chief253
My gauge would read full until the tank was half full and then it would read properly. A added Techron and it improved it considerable. The car is in storage and I didn't get a chance to add it before I put it away. I'm going to continue to add it this driving season.
Old Jan 31, 2007 | 10:21 PM
Chapindad's Avatar
Chapindad
The prodedure is very easy/ But I was disapponted when I opened the windings and they where broke. ;(
Old Feb 1, 2007 | 09:37 AM
ovrebo1's Avatar
ovrebo1
i took it out, didnt look dirty, cleaned it anyways, bent the arm towards the windings, tested it before i put it in, worked, put it in, and now i have the pleasure of watching the bars drop
To gas guage
