C4 weight
Any approximates weights for the entire car with the different years?? (L98/LT1/LT4)
Click the year, then specs. Most of the weight listed, some years have missing data though.
'88 3330
'93 3317 coupe
Here you go. Go to this link, click on the year, you get the curb weight: http://www.idavette.net/facts.htm
In general, it's about 3,300 lbs.
84:
Auto-3192
Manual-3164
85:
Auto-3224
Manual-3216
86:
Auto-3239
Manual-3234
Starting here all numbers are for automatic equipped cars (except for the ZR-1 obviously)
87:
Coupe-3229
Conv-3299
88:
Coupe-3229
Conv-3229
89:
Coupe-3223
Conv-3263
90:
Coupe-3255
Conv-3301
ZR-1-3479
91:
Coupe-3294
Conv-3333
ZR-1-3407
92:
Coupe-3327
Conv-3375
ZR-1-3521
93:
Coupe-3333
Conv-3377
ZR-1-3503
94:
Coupe-3309
Conv-3360
ZR-1-3512
95:
Coupe-3309
Conv-3360
ZR-1-3512
96:
Coupe-3307
Conv-3362
All of these weights are the curb weights out of the book "Cor-vette specs"
All you chubbies out there take note.....
Larry
code5coupe
Almost 200 lbs more for a ZR1
I didnt know it was that much
But it's really not motor weight. The all-aluminum block being offset by the heavy heads, the LT5 and L98 weighed about the same.
However, curb weights are generally established for base cars. So in the case of an L98, that would be with no power seats, no 4 bose amps, no oil cooler, TPS, J55, and whatever other stuff was optional.
The ZR-1 "base" weight is basically a fully loaded car. I would bet that these included options probably add 50-100 lbs to the car.
Then there was the rear wheels, the little extra fiberglass bodywork, the extra quarts of oil and the cooler, etc.
I would imagine a fully-loaded L98 car wouldn't weigh that much less than a ZR-1.
I also have some numbers comparing the LT5 to the L98... the block was 89 pounds lighter, but the extra weight came from: 10 extra pounds from the cams, 17lbs more from the connecting rods, 31 pounds more in the heads, 20 pounds more in the exhaust manifolds, a 25 pound crank saddle, and 26 pounds more in injector housings and cylinder liners.
AQ9 (power seats) 11.9lbs
B16 (leather) 3.5lbs
CC3 (acrylic roof) -6.8lbs
Manual trans -8.8lbs
Z07 22.9lbs
UU8 (Bose premium) 8.8lbs
Even with all those options (not counting the acrylic roof, which removes weight) the coupe only weighs an additional 47.1 pounds. If you subtract the 8.8lbs for the manual trans you have only added 38.3lbs to a manual trans car for all those options.
I'm also surprised by the speaker difference, having removed those things to repair them. It's hard to imagine each individual amp and associated circuitry only adds 2lbs to each speaker.
I seem to recall from Corvette from the Inside the LT5 only weighing about 20 lbs more than the L98. I'll have to flip through it again. Where did you get your numbers from? You didn't account for the wheel and tire differences, though, nor the J55 calipers and rotors vs stock. Nor the tire pressure sensors and whatever receiver stuff there is in the car to monitor them.
The acrylic roof was not standard on either the ZR-1 nor L98 base model.
RE: Lbs/HP. - Divide your vehicle weight by HP. The result is the # of lbs you'd have to drop to have the same effect on acceleration as adding 1 HP. If you're stock, and your car weighs 3307 lbs. with 300chp, then 3307/300 = 11lbs/hp. Dropping those 40lbs for the spare and carrier will have about the same effect in straight-line acceleration as adding 3 1/2 chp. (40/11 or 3.64chp)
drive naked if your that worried about 1lb
