One of out Vette club members has an '88 roadster with a vinyl top. He needs a new top and would like to replace it with a cloth top like another member has on his '93 roasdster. Was the vinyl top factory stock on the 88 MY roadsters or is his an after market. Can a cloth top like on the '93 be installed on his car? Any NCRS guys around that can help?Thanks in advance for your help, Bill
All C-4's came with the cloth. When you replace the top you usually have the choice over which one you choose, there is no difference as to which can be installed. The reasons for vinyl is cost, the reasons for cloth is everything else.
I had a 1992 with a white top, all the white tops were vinyl.
Only the white C4 convertible tops were vinyl. The others were "StayFast" cloth in various colors. GM's reasoning was that white cloth would have been a big cleaning issue for owners. Vinyl is much easier to keep clean and you can use harsher chemicals on it compared to the cloth material.
A good shop should be able to install a vinyl top on the car, but it's hard to say if replacement tops made from vinyl will look exactly the same as the factory top.
While he's at it, he should consider installing a glass rear window. There are conversion kits available for installation and it solves the problem of keeping the clear plastic from scratching. The glass window will fold into place easily.
Anyone have any thoughts on those convertible top rear window "pillows" that Ecklers sells?
Dave
I suspect they work, but in the distant past, an old car that I had came with a very, very soft cotton towel from the prior owner who showed me how to position it. It worked, too.
If I were at it again with a plastic rear window, I'd beat up a very high quality towel, wash the heck out of it to make it soft (and rinse it completely so it has nothing left in it) and use it to prevent the plastic-to-plastic contact that causes much of the scratches.
In seven years of folding up and down that top, I couldn't notice any appreciable difference or change from the day I bought the car, to the day I sold it.
I did same with all my roadsters over past 30+ years and never has scratches on the window.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Brian9
Ron does it seem like something the average joe can do? My top is in perfect condition now but a couple years down the road who knows...
Personally I would rather let the pros do it. I changed out a C3 top once by watching an Al Knoch how-to video and it went well. Nowdays that I have a bit more disposable income I prefer to whip out the debit card and let it do my work. I have heard that Al will rent you a video for the C4 top install also but have not confirmed it yet.
