I noticed the last 3 times I turned on my headlights the left side light struggled to turn into the on postion. Tonight it would not come around completely. I turned the lights off and back on and it open like it should. Any advice on what may be causing this and any suggestions on how to trouble shoot where the problem is?
i don't think the 84 - 87 lights had bushings. i just had to replace mine due to a busted limit switch on the motor (motor continued to turn after headlight was open). cost was about 100 bucks for a remanufactured on ebay. 88-96 problems are usually bushings and very inexpensive to fix.
inexpensive....yes. you probably only need the bushings (3 of them) , not the gear. I bought the gear also anyway because I didn't want to have the whole thing apart only to find out that I needed it. I wouldn't say the repair is easy but take your time and you can do it.
