PCM Connectors.
Old Jan 28, 2007 | 01:11 PM
Brian9's Avatar
Brian9
Default PCM Connectors.
Im installing a BM Shiftplus kit and kinda new to the PCM stuff that you have to splice into its says in the instructions to connect the red wire to the red with black stripe wire on PCM Connector C3 and then the negative wire from the BM module to the light blue w/ white stripe on PCM Connector C4. However i dont see anything telling me which PCM Connector is which I have 4 of them going into the PCM but they arent numbered that i can see.... any help guys? Thanks,
Brian.
Old Jan 28, 2007 | 01:47 PM
Fast Cop's Avatar
Fast Cop
I am going by the FSM for a 96 corvette. The C3 connector is the Gray/Clear one and if you are looking at he back of the PCM its position will be top left. The C4 connector is Blue and its position is top right. Just post if you need more info. Again this is from the FSM for a 96. Good luck with you project.
I see yours is a 95, it should be the same as from the 96
Old Jan 28, 2007 | 02:26 PM
Brian9's Avatar
Brian9
Thanks Fast Cop I took the whole thing out and apparently the blue (C4)and the grey (C3) ones that i was looking for are on the bottom... must be different for 95 and 96... but i didnt know which colors they were until your post so thanks so much for your time and help I cant wait to get this thing in here and go for a drive lol....
To PCM Connectors.
