problems with my hookers
Old Jan 30, 2007 | 10:59 PM
canon1414's Avatar
canon1414
Default problems with my hookers
Has any one else had a problem with their long tube headers on the drivers side touching their steering knuckle. How bad would it be for me to just hammer a little dent in one spot on the headers to make it clear? or would i be able to just bend the tube in a little if I heated it up?
Thanks Mike
Old Jan 30, 2007 | 11:08 PM
Brian9's Avatar
Brian9
Nice title of the thread lol.... keep your pimp hand strong and you wont have any problem with your hookers anymore
Old Jan 30, 2007 | 11:10 PM
ZfidyONE-84's Avatar
ZfidyONE-84
Old Jan 30, 2007 | 11:20 PM
Bad Karma's Avatar
Bad Karma
Thanks Mike
To the other comments... Haha! I was thinking something similar.
To the real question, if you have coated headers you could chip off the coating and have a spot for rust to start.
Last edited by Bad Karma; Jan 30, 2007 at 11:20 PM. Reason: Edited for more bad typing.
Goldcylon's Avatar
Goldcylon
Now thats an attention getter !!!
Old Jan 31, 2007 | 12:33 AM
Vetster88's Avatar
Vetster88
Thanks Mike
Can't heat it and bend it, been there burnt my ego
IF coated your in a pickle.
Take it to an exhaust shop and have them tweak it for you. I had to have one for my el camino modified to clear the upper A-arm, the shop cut it at the bottom and then took a chunk out of the primary at the flange and welded it all back up $40. worth every penny
Old Jan 31, 2007 | 01:22 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
check vaders site - has good into on hedder installations...
Old Jan 31, 2007 | 01:46 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old Jan 31, 2007 | 02:00 AM
mseven's Avatar
mseven
I had no problems clearing , but if you absolutely have to beat on it/her , use a rubber mallet on that hooker.......it won't leave marks or dents....her ceramic won't come off either
Old Jan 31, 2007 | 02:33 AM
Phatoscar's Avatar
Phatoscar
Funny title but as for the headder thing cant you just get like a pipe bender and twick just a little bit?
Old Jan 31, 2007 | 05:08 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
...keep your pimp hand strong and you wont have any problem with your hookers anymore
Exactly, just smack her around a little and your problem will be solved...
Since a tube is attached at both ends (mounting flange & collector) bending may be difficult except by a good shop.
Perhaps you can lay a block of wood on it to hammer a little dent w/o chipping the ceramic coating. Be careful to not hammer too large a dent.
Perhaps there a flaw with that particular header; give Hooker tech support a call for their advice.
Old Jan 31, 2007 | 10:14 AM
ITHZ's Avatar
ITHZ
That Rules!!!!!
Old Jan 31, 2007 | 10:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
Use a LARGE socket (like the size youd use for a wheel bearing nut) and give it a good smack with a deadablow hammer or small sledge. If youre careful you can "roll" the metal and slightly flatten the area...Use a towel under it, your coating will be fine. Just did mone like that awhile back, can hardly even see anything, came out good. No need to heat or cut anything.
Old Jan 31, 2007 | 10:24 AM
DaleD's Avatar
DaleD
Originally Posted by ITHZ
That Rules!!!!!
If Chuck Norris was in 24, they'd call it 12!
Old Jan 31, 2007 | 10:29 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Another one of those thread titles ...
Old Jan 31, 2007 | 10:50 AM
Travis93's Avatar
Travis93
I don't know what is wrong with all of you. I saw the title and wandered what was wrong with his headers.
Old Jan 31, 2007 | 12:26 PM
mikey whipreck's Avatar
mikey whipreck
I've heard this many times before, I believe the answer is buried in the archives...
To problems with my hookers
