Winter Storage Question
Old Oct 4, 2001 | 03:10 PM
USPRIDE's Avatar
USPRIDE
Default Winter Storage Question
I plan on storing my Vette in a carbag this winter. I plan on doing the following:
-Filling my tires to 40lbs parked on tire cradles
-Full tank of gas
-Lots of Irish spring soap/bounce sheets etc to help against mice
-Dry packs
-Use car cover
-Mouse traps
-Plug exhaust with steel wool pads
My question is should I use a gas stabilizer?
I've heard pro's and con's on the subject, such that the stabilizer could damage your injector's. I was wondering what everyone's opinion is on this.
Also, if I missed any storage tips, I'd appreciate your thoughts.
Thanks in advance!!
[Modified by USPRIDE, 1:11 PM 10/4/2001]
Old Oct 4, 2001 | 05:21 PM
Paul G's Avatar
Paul G
Default Re: Winter Storage Question (USPRIDE)
I have been using Sta Bil for years with good results. I would be afraid not to use it.
Old Oct 4, 2001 | 07:37 PM
black bart's Avatar
black bart
I
:yesnod: :yesnod: :yesnod:
Old Oct 4, 2001 | 08:43 PM
c4cruiser's Avatar
c4cruiser
Either disconnect the battery or use a battery maintainer.
Change the oil and filter.
Make sure the coolant protects to -35 degrees.
Wash and Zaino!!
Old Oct 5, 2001 | 03:37 AM
GUMPA's Avatar
GUMPA
I just park on a canvas tarp............cover it with a "Noah"........fill tank........new oil change..........and drive it up and down driveway when it's "nice out"....and it reaches 190 deg..........turn on heater and air condr.........to keep everything lubed and seals from drying out...... :yesnod:
:smash: :smash: :smash:
Wisconsin Winter's
Old Oct 5, 2001 | 08:58 AM
ODA CDR's Avatar
ODA CDR
Default Re: Winter Storage Question (GUMPA)
I had good luck with putting the car on jack stands, to keep the tires from developing flat spots. You cant go wrong with fuel stabilizer. I used large sponges in the exhuast ( I think it sealed better). Use the bug and rat poison in all corners of the garage. Disconnect battery. My 96CE stayed in storage for 4 years and I had no problems when bringing her back to life.
Old Oct 5, 2001 | 12:46 PM
jerryv's Avatar
jerryv
Default Re: Winter Storage Question (ODA CDR)
Don't store it, drive it. All you need is one good day every 2-3 weeks. Your car will like you for it, and you won't go crazy all winter looking at it.
Old Oct 5, 2001 | 12:50 PM
jfb's Avatar
jfb
Car batteries self discharge even if not connected to anything, so use a trickle charger, or put a timer on your battery charger and set it for the minimum daily duration (usually 15 mins). A discharged lead acid battery left sitting will sulfate the plates and its done for .
Old Oct 6, 2001 | 03:32 AM
WOEII's Avatar
WOEII
From: [QUOTE=onedef92]Remember when that spookable closed the door on that mofo and trapped him inside tha
St. Jude Donor '06 thru '11
Default Re: Winter Storage Question (jfb)
What's up with the tires to 40? :confused:
Old Oct 7, 2001 | 01:12 PM
C4 Suke's Avatar
C4 Suke
I kept my car in the driveway for bout 3 to 4 months last winter, no cover or any preparations, just parked it and left it, nothing happened. This time around I'm using the garage and disconnecting the battery, thats about it. What is the purpose of fuel stabilizer, and why would changing the oil really be necessary?
Old Oct 7, 2001 | 08:33 PM
MyC-4's Avatar
MyC-4
Default Re: Winter Storage Question (C4 Suke)
It's a car.....Right?
Cars are meant to be driven......right?
SO DRIVE IT! :mad
Old Oct 7, 2001 | 11:18 PM
djpearn's Avatar
djpearn
Most people seem to forget to check the fluid in the window wash tank. Make sure it wont freeze and crack the pump. Get some good quality stuff , pump out the old stuff, refill and pump it thru the lines and jets. Much cheaper than a new pump.
Old Oct 8, 2001 | 11:10 AM
Bat Man's Avatar
Bat Man
Default Re: Winter Storage Question (WOEII)
In the winter the air in the tires will contract.
Old Oct 8, 2001 | 10:12 PM
billybob's Avatar
billybob
Over-inflating the tires will help prevent flat spots.
To Winter Storage Question
