Every once in a while my 'SERVICE ENGINE SOON' light comes on while I am driving the car, and then the next time I start it up the light does not come on. Because the light comes on only occasionally, I have let this go for several months. The owners manual says that I am risking engine damage if I don't get it taken care of. I am wondering what is normally required to take care of this problem and what the cost is? It is an LT1 engine. I appreciate any advice you can give me on this item.
Thanks, and happy motoring!!
Since the possibilities for an illuminated check engine light are nearly endless there is no answer concerning what it "normally" takes to repair.
As suggested pulling the stored code will at least point you in the right direction. I can tell you that "letting it go" is not a sound strategy since such things almost never repair themselves.
Many parts stores will connect a code reader to check codes for free hoping to sell you a sensor so that should cost you nothing. The same thing can even be done yourself by jumping pins in the ALDL connector and counting the flash codes displayed by the check engine light (MIL).
Replacing the sensor associated with the stored code is NOT the correct way to diagnose or repair the problem in spite of what they may say at the parts store. If you don't have a FSM, and some basic tools for doing diagnosis a better idea would be to take it to mechanic you trust, good luck.
Bloody oath mate, on all counts.
If your pocket is deep enough ill come and fix it for you, and i garrentee it will be done right first go
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You could fly Case from Brisbane to Salt Lake City, round trip for only $1,973.93 US. Might be a bargain. The tab for feeding, watering and entertaining him in style might add a bit more to the cost!
And be warned he isn't a beer drinker, expensive scotch is the poison of choice!
But back onto the task at hand, get yourself a paper clip, look under the dash and connect terminals A and G, turn the key on but dont start the engine, then see what codes you get from it. They should be displayed on the digital screen where the speedo would normally be.
If I had deep pockets I would be driving a C6 Z06. But I do appreciate the info. It will be a while before I can follow up on this because I am in the middle of constructing a garage. I just got the door up today. Still need to finish the OSB and then siding all the way around. Then I can keep the car at my house instead of in a rented storage facility. This forum is great because there so many people who have expertise in Vettes.
Not exactly true. Sensors do wear out and sometimes replacing the sensor is the fix, especially with O2 sensors. But I agree one should fully understand the root of the problem.
I have a 91 that i bought a few weeks ago. Long story short, it now runs. I drove it yesteday on the highway for an hour. trying to get it hot and have the injection cleaner i put in the gas clean the injectors.
anyway my sytem light came on. i see the paper clip method. But can i get the same result by having Auto Zone hook up a tester to the car?
I have to go there today to get a transmission filter anyway
No mate, it is exactly true. Simply cause a code is present does not say the sensor related to it is at fault. There is no 1 DTC in the list states a 100% certain component failure. Sometimes the sensor is at fault, but as TopTechx6 said, replacing parts based on a DTC related to a part is no way to diagnose or repair. If you fix anything this way, you got lucky in more ways than one.
ChiefC, you can get the same result by using Auto Zone to hook up a scanner. Some people like to do things themselves. Sometimes the car wont run and taking it to Auto Zone is out of the question, but as long as you have power in the battery, the paper clip will get you the stored codes any place and any time you like
Don't know if it will help had the same intermitent check engine light come on and go off, put on my tester ( Auto X Ray ) and it said right 02 sensor,but since i have started using a different gas station that sells proper octaine gas and not the cheap stuff the problem appears to have stopped. It's been a few months now and all is well.
