STORM — Cover or No?
Would you advise the use of a cover. What might be the PLUSES & OR
MINUSES? THANKS
It also allows you to sweep the snow off the cover with a broom without risk of damaging the paint surface.
Cover that sucker when you get home from work tomorrow.
The cover will also keep cold drafts from slamming the radiator. This might cut down on freeze problems under the hood.
Huh??? Let's use a little common sense here. Light fluffy snow = ok for a cover, but really, why bother?? It is really only water. Wet snow, not so okay for a cover. The cover will get wet and freeze (adhere) to the vehicle.
And this: "The cover will also keep cold drafts from slamming the radiator. This might cut down on freeze problems under the hood." How a cold draft is going to slam a radiator and cause damage is beyond my scope of understanding. And freeze problems under the hood?, how is a cover going to prevent anything like that. What I know about the cold is that it permeates the entire vehicle and makes it cold all over, and under.
Snow is heavy, SMC is stout, but add some ice, it gets real heavy and it could hurt the SMC. I regularly use a large push broom to remove heavy snow from my Vette (when I lived in Delaware).
The cover does keep a layer of something between the paint and the snow.
Most covers go down under the front rather far, enough to act as a brake against a cold wind.
I have used my old cover during heavy storms in the past, and would do it again.
If you buy a form fitting cover, using it with a lock will help prevent(not totally) the cover from whipping around in the wind.
Do not use a generic one size fits all cover, I did and two things, it doesn't fit right and the sun beat the hell out of it, lasted maybe a month.
I have two Noah covers(one for each car obviously) but never use them because you shouldn't put a car cover on a dirty car and since it's too damn cold to wash my cars, they stay dirty. Besides it's too much trouble to remove the cover everyday anyway.
It won't scratch your car as long as the cover and paint are clean. (Don't ever put a cover on a dirty car, or the cover will get dirty.)
I have a Noah cover for my vette and don't use it anymore, but it's elastic on bottom and fits like a glove, plus it covers the wheels from cat ****, and of course tie it down tight.
My car sends some of the winter outside, and I use a cover. If your car gets a coating of ice on it, the ice can scratch the paint as it slides off. I always use my cover in the summer months as well, as anything you do to protect your paint from the sun is very good for your car.
But, make sure it is the form fitting. And yes, there are expensive covers that scratch brand new, and don't work either (CoverKing, comes to mind; see thread in C6 Gen.$ 340+/-).
Also, while Mr. Mojo is correct, the lock and cable will help keep it from blowing off, do one more thing. Tie a piece of string to one of the eyelets, then string it betw. the two eyelets by throwing it under the car attached to one end of the cable. Then, cinch it tight so the cover is pulled tight along the bottom and tie it up thru the eyelet. You can do this in addition to the cable; I did for years. I also twisted one end of the cable in a couple of small circles to pull it tighter under the car as an added precaution.
Reason? Eventually the elastic around the front back and sides weakens. As it does, wind blows under the cover and will eventually billow it up and out. I do know from experience and actually watching it happen once. Only once. The more the cover billows and bounces around on the car, the more the chance for scratching even if it's the softest material going.
Lastly, yes, it might ice and freeze a bit, but generally it won't stick to the the paint. Let it all thaw, naturally. I've brushed off the snow very lightly, and even scraped the cover. Not a good idea. Probably took two years of life off the cover, an Evolution (no, not a Mitsu....). Just let any snow or ice left melt naturally.
Hope this helps you.
