Pre-Cat Advice
My question concerns the front Y-Pipe and Pre-Cats. Should I go ahead and replace that also? And if I do, should I go without the Pre-Cats? If I do go without the Pre-Cats, will it mess with my emissions system and give me unwanted warning lights on my dash.
My overall goal is a SLIGHTLY louder and deeper exhaust note with a little more performance. I don't race it.
I noticed my Fiancee's 2004 Honda Accord is quicker than my Vette. That just doesn't seem right!
Anybody in Texas able to confirm this?
I was wondering if no precats and a high flow main cat would pass down here (we do get the sniffer test)???
Wanting to do this type of thing....but.....want to keep it legal as I can.
the money in headers. Look at the full Melrose system and dual cats. I believe it was designed for the Corsa mufflers. That is a much better use of $1500 IMO.(You might even catch that damn Honda).
I also installed a Magnaflow hi-flow cat with the air hook up. Then I put on Magnaflow straight through dual outlet mufflers. I would guess I may have picked up 20 CHP. I sounds good but not loud until you go WOT. I only spent about $400, but my system isn't stainless. I want my car to look stock.
It is also MUCH more expensive.
For the rear Y-pipe, Walker makes a pipe with a balance tube to cut down on resonance. For mufflers, you can go without or use something like the Mid-America Muffler Eliminators that are simply a pair of small glasspacks on each side. I have the muffler elim's on my 87 with an otherwisw stock system and it has a nice sound but no interior resonance. WOT acceleraton does bring out the noise, but when you cruise, there is a nice deep sound but nothing obnoxious.
Corvette Central (a Forum vendor) has a bolt-in true dual exhaust system for L98 cars for about $250 and all you need to add is muffflers. They are bent to fit and should provide an increase in power. But this system does away with the cats entirely and IMHO, it's not a good deal for air quality. Bremerton is not bad right now, but it may not be long before counties around King, Pierce and Snohomish may see emissons testing.
The Corvette Central system would allow for some small universal cats, you just have to have them welded in and connect the AIR tube to one of them. Then add your choice of mufflers.
Our stock front Y is restrictive and so is the main cat if you bump power into the 300chp range, easy to do with a late L98.
A good cat only flows to about 450cfm, if that; that only supports 205 hp at the crank.
Look for allen stainless and Corvette exhaust using a google. You'll find allen stainless. They make an oversized 2.5" (304?) stainless front "Y" without cats (maybe with cats too). Anyway it's not shiney, it's a heavier stainless that's common in front exhaust systems. It's brownish in color. Good stuff. I believe this version of stainless has even better high temp properties.... At any rate....
Stainless lasts longer than alum. You can also buy alum from them for less money. If you don't see the item listed, call. They still have it. The oversize diameter will help alot. It did on mine. Before installation, I wouldn't put mine in 6th (I have 3.33 hwy rearend) until 70mph. (At that speed, it was running 14k rpm. It was rediculously slow and lugged). Just by putting the larger pipe on, it doesn't lug until 60mph. MORE POWER!
It's what I recommend you put on the front. And, it's the company I recommend you buy from.
gp
FYI: Your front, stock Y pipe is 2.25". The factory header outlets are 2.5". This oversize exhaust is just what the Doc ordered!!!!!!!!! This will provide as much (or more) improvement as headers (WHEN YOU LOOK AT CHANGING THE EXHAUST PIECE-BY-PIECE). Headers cost about a grand for a good set. This upgrade is 1/5th that. You figure it out.
If I go with a bigger front Y-pipe will this mean I have to do something special to hook it up to a stock cat?
However, the higher the rpms, the closer it gets to a constant flow and the more dual pipes would improve your performance.
It is my opinion that the best improvement (over stock) is to use a 2.5" front Y pipe (with front cats), a high flow main cat, and performance (or no) rear mufflers. You'll still be legal in any state.
Of course, TRUE duals with an Xpipe, hi flow bullet cats, and headers are even better -- but that's not stock any more....
gp
Note: The Y pipe comes with an O2 bung and requires not computer changes. It does not throw codes. Also, if you're not familiar with exhaust systems, you should know that cats act like mufflers. They do provide considerable quieting power. Having GOOD replacement (hiflow) pre and main cats w/o any mufflers will give you the best performance, sound, and emissions of any setup. (Assuming you're concerned about emissions).
dtomar, you can buy 2.5" front y-pipes and I would suggest that IF you are going to replace the front y. On mine I didn't replace it because it was in good shape. If you replace it, I would suggest getting a new O2 sensor to install in the new pipe near the flange.
I would agree that replacing the O2 is a must. I've heard NOT to use Bosch (which I did). I forgot what's currently recommended.
gp
