Brake Light on Dash
Old Feb 21, 2007 | 03:40 PM
gmanvette's Avatar
gmanvette
Default Brake Light on Dash
What things can cause a steady brake light on the dash?
Old Feb 21, 2007 | 03:48 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The most common would be low brake fluid.
Old Feb 21, 2007 | 03:54 PM
DaleD's Avatar
DaleD
I have the same problem. Duh! I just assumed it was the e brake cable. I'll check that tonight! Sometimes the obvious is hardest to see. Does it take any special brake fluid? (I'm a new 87 owner, no the 87 isn't new, I am).
Old Feb 21, 2007 | 06:33 PM
jesters94's Avatar
jesters94
2016 C4 of the Year Finalist
2015 C4 of the Year Finalist
Check and make sure your e brake is completely disengaged. The brake light only comes on when the e brake is set, even slightly.
Tim
Old Feb 21, 2007 | 06:37 PM
Bad Karma's Avatar
Bad Karma
Tim
Yeah, even one notch up and it will light up, but not be enough to really engage the brake.
Old Feb 21, 2007 | 06:43 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
Old Feb 21, 2007 | 09:13 PM
gmanvette's Avatar
gmanvette
Could malfunctioning ABS cause a brake light? I don't know if there is a seperate ABS light on a 1988.
To Brake Light on Dash
