Window installation tips?
Old Feb 22, 2007 | 08:53 AM
jrace's Avatar
jrace
Default Window installation tips?
Anyone have any tips on installing a passenger window on a 94 coupe?
Just got one off of a 90 vert and need to get this done ASAP. Last one shattered.
Old Feb 22, 2007 | 02:44 PM
1quik91's Avatar
1quik91
ASAP? It will take awhile if this is your 1st time, even if it isn't. Need to take off the door panel, remove the felt guides at the top, (mark them) and the remove the door support panel and hardware just to get to the window. There will be two bolts holding on the window, take off and pull window out thru the top. Remember how things came apart, you need to reverse the process to install. Will need to use some well versed cussing!
