Dash speaker grill.... Question
Old Feb 24, 2007 | 01:22 PM
Vetster88's Avatar
Vetster88
Default Dash speaker grill.... Question
How do I get them out of my dash? Already attempted prying but the dash didn't like that. I have a dash cover to put on and the speaker grills are what's holding me up.
Thanks in advance
Old Feb 24, 2007 | 02:02 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You must pull the dash top out of the car as the fake speaker covers are bolted on from underneath. There are 2 screws that hold the dash in place at the defroster outlet and another 3 (can't remember, possibly 4) underneath the front lip of the dash top. These are all located above the instrument panel, there are none on the right side.
Loosen these and give a good yank toward you after you have lowered the steering wheel. The pad is held in place by some large metal clips by the windshield base.
Old Feb 24, 2007 | 02:10 PM
Vetster88's Avatar
Vetster88
That's a little bigger task then expected. I figured all I'd have to do was pop and glue...oh well, it'll be worth it.
Thanks for the steps and pics much appreciated
Old Feb 24, 2007 | 02:11 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Be VERY carefull, these dashes are getting old and brittle, and if you crack it, it WILL ruin your day
Old Feb 24, 2007 | 02:15 PM
Vetster88's Avatar
Vetster88
It's already cracked That's why this task has been started. I have a plastic dash cap to cover it with, so my day won't be ruined any more
Old Feb 24, 2007 | 02:29 PM
corvetteronw
Cruise-In VIII
As you can see from the pic, I dyed mine to match the interior of my 87. Do not do this! It reflected on to the windshield and made quite a glare. Also I did not remember to prep it before the color change. Probably some kind of silicone spray was used on it in the past so the dye started to peel off. I just called up www.vette2vette.com and he sent me a used one for $99.
Old Feb 24, 2007 | 03:26 PM
FLA-C3's Avatar
FLA-C3
Active Streak: 90 Days
I'm currently refurbing my '88 interior and have the dash pad out...here are a couple pics that might help.
Shows the bottom of the dash pad with the grilles removed...see forward clips...
Shows the slots in the dash frame where the clips on the pad slide in and where the 3 screws go...(yes there are two more at the defroster vent also)
To Dash speaker grill.... Question
