lowering kit
Old Feb 25, 2007 | 06:08 PM
arandy's Avatar
arandy
St. Jude Donor '08
Default lowering kit
What is the most drop anyone has gotten with a lowering kit. I hear people say 1/2-3/4 in. I need a full 1in. Late model verts look like 4X4's at stock ht. I know the back is no problem, I'm just interested in the front.
Old Feb 25, 2007 | 06:56 PM
89vert's Avatar
89vert
I"m lowering my vert and I'm going to use the kit from Corvette Central. The verts have shims above the springs that I don't think the coupes have. I'm going to leave the shims out and see what it looks like. Here is a picture to show the shims I'm talking about. Hope this helps Tim
Old Feb 25, 2007 | 07:45 PM
corvted's Avatar
corvted
I almost got an inch by shaving some of the material off the wedges that are provided in the lowering kit. Click on my photos if you want to see how it turned out. I was happy with the results.
Old Feb 25, 2007 | 07:56 PM
Brian9's Avatar
Brian9
Read this post:
http://forums.corvetteforum.com/show...7&postcount=51
from this thread:
http://forums.corvetteforum.com/show...ht=torchredrob
Lowering my car is my next project as well.... Let us know how it turns out for ya
Old Mar 3, 2007 | 03:08 AM
n1kki6's Avatar
n1kki6
People rip on imports all the on this board and I hate to say ricer but if you lower your vette in this manner it's not much off from the ways civics lower there cars. It's a great double standard.
Old Mar 3, 2007 | 03:15 AM
n1kki6's Avatar
n1kki6
If you just want the look then go half assed with the bolts and pulling the shims. But so many people tear on imports around here for the same reason but it's different when vettes do it. If you want performance fo with some coil overs. Since I havent posted in a while and don't seem like a spammer. http://www.dougrippie.com/drm/suspension_components.htm
I just hate the corvette contradiciton. These cars are already agressive, but if you want the performance to match at least the sports cars of 11 years beyond be ready to drop a little bit of cash. If its just the look then roll with shim/bolt drop.
Old Mar 3, 2007 | 12:41 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What are you smoking?
There are room for smaller shims and pads without causing spring contact with anything.
And the bolts simply make the rear spring adjustable by spinning a nut.
(Hey, kinda like a coil over.)
Ricers do hack jobs by cutting coils on their springs or clamping parts of the spring together (accident waiting to happen.) We are simply changing the spring mounting location, not messing with the spring itself.
Sorry the solution isn't expensive enough to please you.
Shorter wedges and longer bolts, and cutting most of the spring pad off the end of the front spring will get you about 1".
Old Mar 3, 2007 | 01:12 PM
95PoloVert's Avatar
95PoloVert
Active Streak: 90 Days
I installed the kit on my '95 Vert, removing all shims, etc...let it settle, and it only dropped about 3/4".
Tore it down again, and removed a couple of layers out of the sandwiched pads under the tips of the springs, gluing on a patch of truck innertube when done to prevent any metal-on-metal contact.
The car dropped an additional 1/4" - 3/8" with no apparent adverse affects in the 2 years or so since.
Old Mar 3, 2007 | 01:32 PM
n1kki6's Avatar
n1kki6
The point wasn't about it being expensive. I'm not some price tag corvette tax type of person. Screw it, I'm out again. I shouldn't have even posted. Sorry.
Old Mar 3, 2007 | 02:09 PM
95PoloVert's Avatar
95PoloVert
[QUOTE=n1kki6;1559207610If its just the look then roll with shim/bolt drop.[/QUOTE]
Lowered Cg reduces weight xfer during cornering, so this isn't just an appearance mod.
For me, the incremental cost for coilovers just isn't worth the incremental benefit.
YMMV
Old Mar 3, 2007 | 06:20 PM
CentralCoaster
If you have a point, I'm all for it.
We could also rehash some old sh** about coilovers vs. composite leaf, like here:
http://forums.corvetteforum.com/show....php?t=1406540
and here:
http://forums.corvetteforum.com/show....php?t=1412764
Although you were specifically saying using longer bolts and shorter wedges was a half-assed method.
Old Mar 3, 2007 | 10:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Well yea I suppose you "could" go out and buy a flatter spring...but why...
Sometimes the simple method also is the most elegant method...
Old Mar 3, 2007 | 11:20 PM
Onlya1's Avatar
Onlya1
Default Lowering
Longer bolts in the rear and I removed the shims and shaved the spring pads. My 87 vette is sitting nice.
To lowering kit
