'84 Headlight Alignment
Old Mar 1, 2007 | 09:33 AM
IndyVette84's Avatar
IndyVette84
Default '84 Headlight Alignment
Hey, all
I replaced my headlight motor on the driver's side and I'm having a difficult time getting it to line up correctly back in the hood---the inside side of the light looks like it's lower than the outside side--I can't figure it out..am I missing something simple?
Your pal,
Jason
Old Mar 1, 2007 | 10:06 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
There are four 10mm bolts that adj the highth of the top cover that you get to by taking the lamp cover off. Once you get the asm centered in the hole, raise or lower th flat cover until it aligns perfectly and then tighten.
Old Mar 1, 2007 | 10:59 AM
IndyVette84
Hey, Thanks!!
I will try that and let you know how it goes!
Many thanks
Your pal,
Jason
To '84 Headlight Alignment
