Radiator Fan
Old Mar 2, 2007 | 01:37 AM
glide's Avatar
glide
St. Jude Donor '13,'19
Default Radiator Fan
The 1985 Torch red project Vette is down again. Radiator fan this time. Seems simple enough, Does any one know how to diagnose and repair one? Which wires, relays and switches to check and how? It just doesn't come on, ever, whiles sitting in traffic and temp is rising into the two hundreds. Appreciate it!
Old Mar 2, 2007 | 01:53 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's only supposed to come on at 228 degrees, or when the a/c is on.
Do you have the secondary fan in front of the radiator also, or just the one primary fan?
The relay is on the inside of the drivers side fender liner, kinda closer to the brake master.
Old Mar 2, 2007 | 02:02 AM
Brian86's Avatar
Brian86
Stick a paperclip in terminal A and B of the ALDL and turn the key "on" (like checking for codes). This turns the main fan on and energizes several sensors and relays. The fan should run.
If you need to replace the fan. Here are the details on a new fan:
ACDELCO Part # 158498 {#22137318}
MOTOR KIT,ENG COOL FAN 150 WATTS; w/o FAN(B4P) or HVY DUTY CLG(V08)
Old Mar 2, 2007 | 07:20 AM
glide's Avatar
glide
When I recently checked the TSP voltage I shorted A & B of the ALDL and the fan didn't come on.
228 degrees seems alful hot. The anti-freeze is boiling by the. Rafiator gugling, etc.
Thanks! I'll check the relay.
Old Mar 2, 2007 | 07:59 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
228* is correct and your coolant WON'T boil at 228*. That's why they call it coolant, it raises the boiling point.
Old Mar 2, 2007 | 10:29 AM
CentralCoaster
And more importantly, it's under pressure, so the coolant can actually get up around 260*F before it starts boiling.
Old Mar 3, 2007 | 12:28 AM
glide's Avatar
glide
Can I make it come on sooner? I don't like my car running that hot. Especially being that old and driving in stop and go traffic! 115K
Old Mar 3, 2007 | 01:08 AM
CentralCoaster
You can either reprogram the chip.
Or install a fan switch. This can either be an override switch, that lets you force it on from in the car,
or it can be an aftermarket temperature switch from Ecklers that automatically turns the fan on at a certain temp. Some places even have adjustable ones.
Old Mar 3, 2007 | 08:35 PM
glide's Avatar
glide
I read a thread about the switch. Thought it was the A/C - heat fan they were talking about.
Aftermarket adjustible switch from Ecklers huh? Where do you install it? Ecklers on the Internet?
Brian - You sure its supposed to come om with pins A & B shorted? Don't think it does. How do I narrow it down to the motor. Fuse is good. I'm going to go beat on the relay!
Old Mar 3, 2007 | 09:36 PM
CentralCoaster
Yes, its supposed to come on with the top right pins jumpered and key on. When you do this, the ECM grounds the fan relay, and most of the other stuff on the car. Brian knows his stuff on cooling fans.
Old Mar 4, 2007 | 09:59 AM
BADDUCK's Avatar
BADDUCK
Close the hood and get a manual.
Old Mar 4, 2007 | 11:23 AM
glide's Avatar
glide
Thanks! Found and am ordering the low temp switch on Ecklers.
I have a Haynes manual.
I'll get a relay (cheap) today at Autozone (only store open). If that doen't do it, then I'll check the fan motor
To Radiator Fan
