window leaks
Old Mar 2, 2007 | 01:14 PM
Hanny93's Avatar
Hanny93
Default window leaks
I have a 93 that I put all new window molding in. But i am still chasing water leaks. How easy is it to adjust window glass? anybody delt with this? Thanks.
Old Mar 19, 2007 | 09:45 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I find that with my C4 no matter what I do, the windows leak. I think it is inevitable with these models.
Old Mar 19, 2007 | 02:17 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
The windows are adjustable. The procedures are in the FSM. You can make a C4 not leak but it does take some time.
Old Mar 19, 2007 | 03:18 PM
Fast Doc's Avatar
Fast Doc
Grease the weatherstipping first with silicon grease. That may well solve the problem, and it will make it very easy to see where it's leaking if that persists.
Old Mar 19, 2007 | 03:44 PM
bryantbjb's Avatar
bryantbjb
Then you will have a problem shutting the doors - no way for the air to escape - just another fun issue.
If you just purcahsed new seals - check for proper allignment. You might want to look at your front windshield seal as well - they get really dry over time.
Good luck.
Old Mar 20, 2007 | 10:49 AM
Sam Lam's Avatar
Sam Lam
Tom: Please describe to location of the leak on your window. The opportuities for correcting the problem will be determined by the location of the problem. I just installed new WS (GM) on my 89 and had to do some adjustments to get a proper seal. There is also a procedure to adjust the window in the tech section. The location of the leak is needed to assist you.
To window leaks
