I've heard lots of horror stories about rotating tires across a car because it reverses the normal rotation of the tire. Is there anything to this? (Assuming, of course, that the tires are in fact unidirectional!)
I'm asking because I keep wearing out the outside of the left front tire. No, it's not an alignment problem. See, there's this hard right turn on the way to work at the bottom of a hill. There are no houses in the area, and there's a clear view through the turn, so I tend to punch it through there. Due to the turn and the hill, all the weight shifts to the left side and the nose pushes out, sliding towards the left side of the road. It's great fun but hard on the outside of the left front tire.
So I'm wandering about rotating the front tires across. Bad idea?
From: The reason time exists is so everything doesn't happen at once
The general rule with radial tires is not to switch sides, even with non-unidirectional. You can "rotate" them by switching the right front and rear and the left front and rear (assuming front and rear are the same size). But you shouldn't put a tire from the right side of the car on the left side unless you remove it from the wheel and mount it "inside out" on the other side of the car.
This was the case with the old steel belted radials of the 70s and 80s.
Not true of Today's tires.
Unless you have a directional tire (which is clearly labeled on the tire sidewall) todays' tecnology allows tires to rotate in ether direction.
Now, as far as most current corvette tires, they are directional.
My wife's 2004 Chrysler van does recommend switching rotation directions in the owner's manual, and I've done it without any problems.
I was unaware of that. Thanks for bringing me into the 21st century.
The "new" theory as to rotating tires is as follows:
If the car is front wheel drive, do the following:
The front wheels remain on the side they're on and are simply moved back. Ex. - the LF tire is moved back to the LR side. The rear tires are crossed and go forward. Ex. - the LR tire is moved to the RF side.
If your car is rear or 4-wheel drive, do the following:
The rear wheels are simply moved forward. Ex. - the LR tire is moved to the LF side. The tires in the front are crossed to the rear side. Ex. - The LF tire is moved to the RR side.
Obviously, this only applies to tires of the same size. There are some tires out there that cannot be rotated even if the sizes are all the same. Ex. - Goodyear Aquatreads are directional and cannot be rotated. These tires have an arrow on them pointing in the direction they MUST follow.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by corvettedan22
Why dont you take the corner harder on the way home !!!!!!!!!!!
This should even things out.
Or increase your camber on that side to keep the tire from rolling over. Think of it as a road course alignment. The cars are always adjusted differently on each side.
Switching from side to side could have other effects, one being that the wheel (unless it's a non directional) will be facing the wrong way and that can cause brake cooling issues.
There is only one way I rotate my tires, by doing a burnout!
Increase the front inflation and add some camber to the front wheels.
Oh, and do try and make some left hand sweeps...
Also trail brake going into the turn and get the car rotating a bit, then nail it and slide the rear on the way out. Oversteer is much more fun than understeer. (Don't forget to turn off the ASR)
