Interior Courtesy Lights
Old Mar 3, 2007 | 10:38 AM
RH53's Avatar
RH53
Cruising
Default Interior Courtesy Lights
I am new to this forum.
I have a 1991 Corvette coupe. My courtesy lights mounted in the arm rest, the map lights in the mirror, and the lights in the radio buttons are not working. I have checked the fuses, they seem to be ok. Any suggestions ?
Old Mar 6, 2007 | 09:32 PM
rodder robert's Avatar
rodder robert
My '93 has a relay behind the dash on the drivers side that controls the interior lights, mine was missing because the passenger door switch was out of adjustment and whey I hit a bump the interior lights would flash.
Old Mar 7, 2007 | 09:12 AM
RH53's Avatar
RH53
Cruising
Thanks for the tip.
I need to take the instrument cluster out anyway. I had some work done at a Chevrolet garage and they didn't get the connections tight to the instrument cluster, so only half of it is working currently. I'll check for the relay when I have the cluster out.
Old Mar 7, 2007 | 03:26 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Mine went out on my '91 a few years ago.
IIRC, there are a couple of fuses under the right hush panel and one of them had blown.
IIRC again, there is a fuse in the fuse panel that says CTSY or something like that on it.
May want to check that one.
Good luck with it.
Old Mar 7, 2007 | 03:59 PM
elhefe's Avatar
elhefe
Default Access to fuse and relay panels
I also have a 90' Coupe with a non working Horn and my curtesy lights are not working. I have been directed to the Relay panel and aux fuse holder behind the right side inst. panel. For the life of me I cannot figure out how to gain access to it. Most corvette owners I have talked to said "it's behind the panel just pull it off" I still cannot see where I can get the panel removed without breakng something. The knee bolster is covered by a carpet type fabric that is glued on. I do not see any ready access screw holes. I am sure once I get the panel off and see the relays and fuse holder I can figure out the problem. My car is coming up for inspection and I need to get this resolved before the end of the month or it sits in the garage. Thanks for the help in advance. Steve
To Interior Courtesy Lights
