From the reading I've done I would stay away from spacers and adapters. The offset on the early C4's is 38mm. The latter are 55m. It's getting harder and harder these days to find newer wheels with the 38mm offset.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've been on this forum for 5 years and never read a single thing about a failure of either.
Adapters bolt to the hub and are as strong as the wheel.
I don't mean to imply that I'm an expert at this by any means. But the couple of mechanics that I know personally have told me to stay away. The reading I was referring to were not posts on this board.
I am just saying I personally would stay away from them.
I'm running the adapters on my '84... with 2002 SS Camaro 5 Spoke wheels.
For you flame throwers... NO I HAVEN'T been able to tear them off and if ANYONE could it would be ME!!!!!!
My adapters aren't anything special, just some I bought here on the forum. Plain vanilla, fairly cheap adapters that have been throughly tested by me in both lateral directions.
They've held up just fine and I've done most everything to break them except sliding up against a curb.
I might not trust them to road race with'em myself but for driving around out here in the 'civilian' world, they're 'just fine'.
My Crossfire hasn't got enough power to test them properly in the 'radial' mode. Not that I haven't tried.
I'm sure mechanics see all sorts of amusing things though. For example, I saw this kid trying to buy new studs for his adapter because they were all bent inward and two were broken. Looked like he was using a Chevy bolt pattern on a Ford wheel and they all bent in when tightening it. The idiot would have had to use a hammer to even get the wheel partway on.
I told the idiot to throw the adapter in the garbage and get the right one for his application before his wheel falls off.
