The Tools We Use
Old Mar 6, 2007 | 11:13 AM
deerra's Avatar
deerra
Default The Tools We Use
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands, so it smacks you in the chest and flings your beer across the room, splattering it against that freshly stained, heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Yeou Shhhiiittt!..."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood blisters. The tool used most often by all women.
BELT SANDER: An electric sanding tool commonly used to convert minor touchup jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy-duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub that you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or ½ socket you've been searching for the last 45 minutes.
TABLE SAW: A large, stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes, thereby ending any possible future use.
RADIAL ARM SAW: A large, stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford, and instantly rounds off their heads. Also used to quickly snap off lug nuts .
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Women primarily use it to make gaping holes in walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need.
Old Mar 6, 2007 | 11:20 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
A classic!
Old Mar 6, 2007 | 12:12 PM
Bigredwing's Avatar
Bigredwing
Good to see the list has grown. Thanks for sharing!
Old Mar 6, 2007 | 12:15 PM
Bob CTS's Avatar
Bob CTS
That's good, enjoyed reading.
Old Mar 6, 2007 | 12:17 PM
c92vette's Avatar
c92vette
Hilarious!!! One of the best I’ve seen lately. Thanks
Old Mar 6, 2007 | 12:49 PM
ogres84's Avatar
ogres84
Perfection !!!
Old Mar 6, 2007 | 01:04 PM
runner140*'s Avatar
runner140*
Love your take on tools. I'm sure we can all relate to some of those descriptions.
Old Mar 6, 2007 | 02:38 PM
flyinlow90's Avatar
flyinlow90
All pretty good but I liked this one the best. Thanx.
Gary
Old Mar 6, 2007 | 02:48 PM
ogres84's Avatar
ogres84
Gary ?? Go stand in the corner until the Dr. says you can mingle with us..
Old Mar 6, 2007 | 02:52 PM
flyinlow90's Avatar
flyinlow90
Old Mar 6, 2007 | 05:17 PM
champs65's Avatar
champs65
Old Mar 6, 2007 | 05:36 PM
ZfidyONE-84's Avatar
ZfidyONE-84
classic
Old Mar 6, 2007 | 06:32 PM
jesters94's Avatar
jesters94
2016 C4 of the Year Finalist
2015 C4 of the Year Finalist
Toooo funny
Old Mar 6, 2007 | 08:37 PM
deerra's Avatar
deerra
Just to clarify, I didn't write the funny stuff. I received it in an email and though everyone would enjoy and get a laugh. I laughed my butt off as I can relate to a number of them.
Old Mar 6, 2007 | 08:55 PM
nitecruizer's Avatar
nitecruizer
Gee and for a minute I thought you were my wife, she spreads tales after picking herself off the garage floor from laughing at my mistakes and calling all her friends and telling the about the latest OOPPP's. Unless she calls the E.R. and tells them I am coming again.
Cruizer
Old Mar 7, 2007 | 06:58 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
I'm SO relieved.
I have all those tools.... and have been using them properly all along, just like those 'directions' say.
Old Mar 7, 2007 | 08:03 PM
aminnich's Avatar
aminnich
Add to that: Usually found in the garden to mark the vegetable rows. Best purchased in pairs with the optional string to keep the row straight.
I am sure this is correct as that is where I find mine every spring.
To The Tools We Use
Old Mar 7, 2007 | 11:11 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I was going to say that it is obvious that you have "experienced" all those things. I know that I have, especially in my job as a shop teacher.
Old Mar 7, 2007 | 11:28 PM
RWD_tech's Avatar
RWD_tech
nice...i like the engine hoist one
i should post that up at work
Old Mar 8, 2007 | 06:06 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
Looks like I use my tools right!
