I have this elusive issue at hand. Before when my 1991 6spd threw code 44 it was always the O2. This time is different. I am now on my third O2 and still having problems. O2 #1 was a heated Bosch that lasted about two months before throwing a code 44. O2 #2 was a Bosch 1 wire that lasted 80 miles then threw code 44. O2 #3 is a beautiful Denso 1 wire which lasted one five mile trip also throwing code 44. I have been skeptical all along, but especially after the Denso had problems. Tonight i ohmed out my injectors and checked the MAP. Both were perfect. TPS is set properly. The code is always thrown at low RPM. Mostly after driven, at idle, in closed loop. Car runs great in open loop and cruising, but when you let off the gas down a hill in closed loop it jerks and twitches. Any help would be appreciated.
I also have a new cat, IAC valve, and AIR pump. EGR is disabled in tune, but valve is still in place and riser pipe is blocked off. It has had this setup for about 8 months with no issues.
Do you have a FSM? If not you need one. Since replacing the O2 sensor did not fix the problem you may have a bad connetor, wiring to the sensor or from the ECM, mechanical problem, or water entering the fuel tank via stopped up drain. The FSM (factory service manual) gives a detail description on how to follow and fix the problem.
Simply cause you get a code to say its lean does not mean replace the sensor. There is a load of things that can cause it to think its lean. (doesnt even mean it is lean, just that the sensor says it is)
Check the EGR system to make sure its not allowing any air through into the intake. (i know youve got it disabled, but some of it is still there, so it can still leak.)
Check the AIR system to make sure its not blowing air into the exhaust stream when its not meant to. Also check to see there is no exhaust leaks between the header and the head, and make sure its not able to suck any air in anywhere else before the O2 sensor.
Get onto it with DATAMASTER so you can see what all the sensors are doing and saying at the time of the issue, measure the fuel pressure, measure the vacuum at idle, and check the connections at the ECM for a nice tight clean fit.
From: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
When I had the code 44 in my 91 it was the injectors . I ohmed them and they we're everywhere from 5. to 17. only 2 were were they should have been. I know u ohmed yours already and there fine but thought I'd share my experience with you . Once I replaced the injectors I haven't seen that code since ( about 2000 miles put on after the replace ).
Checked out ECM wires tonight. It all looks good with no shorts and the ground is good. I re-routed them anyway to make sure everything was good and would stay that way. I checked the fuel door drain and it was very clogged. I cleaned it out and will drive the car before I add anything to the tank to see if the wires solved the problem. Then I will move on to the water issue. Thanks for all your help guys!!! I will keep you posted until we solve it completely.
I am having the EXACT same issue as you are. I'm interested to see if you figure yours out. I've had my car in the local corvette shop, and they couldn't pin point the problem either....mainly because when my car was in the shop the code wasn't being set, but as soon as I get the car back...code 44 every day.
I'm beginning to think it is injector related, because the code only comes on after the car has been sitting for some time (say during work, or over night). Then after driving it for a while the code goes away and the car seems to run great. I wonder if and injector(s) is leaking a tiny bit while the car is off. Although, with that condition it makes me think the car should be running rich (code 45 instead)....and I seem to be getting worse gas mileage lately.
I too have replaced the 02 sensor a few times, also the IAC, vapor canister, vapor canister solenoid, fuel filter, egr solenoid, checked for vacuum leaks, etc.
Ohming the injectors only tells you if the coil is good or not. You could have an injector that is not functioning properly an still ohm out as good. An injector could be stuck?
Can you rig it up to read the o2 sensor as you drive?
The car ran great on Thursday going to work, but it still felt a little "off". So at lunch I went by Walgreens and bought a couple of bottles of iso alcohol. I added about 3/4 of a bottle to a 1/4 tank of gas. I then drove it around stop and go for 45 min and it ran better than it has in months! I drove the car all weekend and it has not missed a beat. I am going to add a little to each tank for a while to make sure the water is all gone. Thanks for all of your help! That code 44 troubleshooting page helped tremendously. Thanks again.
Ben
So, your conclusion is that you are getting moisture in your gasoline? and adding isopropal alcohol to the gas tank will help get rid of the moisture?
That was my conclusion until today. It was running badly again and threw codes 41, 53, 72, 74, & 44. Now i conclude that i must have a bad ECM. What do you guys think?
Yep, let us know. Also you are actually also adding water to the tank when you use Isopropyl alcohol. If you have to get rid of water in the gas tank use a bottle of Heet.
Heet is the only moisture removal from a bottle method I have heard of to remove water from fuel.
After reading your post, on Monday I threw a can of HEET in my car, and (knock on wood) the SES light hasn't reappeared and has been running fine. I'm going to put another can in next fill up along with some Chevron Techron fuel system cleaner. Maybe the 18 year old fuel system just needs a little TLC.
