From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by JA94vette
So, that paint from the rattle can will hold up to the heat???
ABSOLUTELY!!!!
The rotor gets hot, not the caliper. Ever notice the little rubber dust cap on the bleeder doesn't melt?
This is the reason some will spend extra money for "caliper paint".
Before you doubt this post, try it. Then you'll learn.
Knowledge, is a wonderful thing.
if the calipers ever get hot enough to fry the paint, the brake fluid would boil away. fancy caliper paint and fancy packaging - clever marketing scheme!!!
If I'm not mistaken, the stuff marketed as caliper paint is a brush-on material. That would be good for the folks that don't want to remove the calipers from the car. Otherwise, rattle can is good if the surface is cleaned well.
The fastest way to clean the calipers and around the shock area is air compressor. It'll sandblast the grime right off ready to paint. Get some newspapers, tape and cover everything up. I guess I'll be painting mine now after seeing this thread.
If you feel like brushing instaed of spraying, just spray some spray paint into a container and use a brush.
Was bored on a rainy day and while I was rotating the tires I saw my sons model paint kit, hmmm, "I wonder how the red would look." Worked great and is still looking fine. The break dust will adventually overcome them if you don't clean them periodically. I figure any durable paint will work.
