Combining shock brands / types
Old Mar 11, 2007 | 07:32 PM
SEA4's Avatar
SEA4
Default Combining shock brands / types
Just for conversations sake... I've been thinking about the possibility of combining 2 different kinds of shocks..
Say you are on a budget and occasionally autocross your car..
Are there any cons or potential problems by using a non adjustable performance shock (like the Bilstein Z51 shock) in the rear and spending the greater portion of your shock budget on the fronts? (like for some QA-1's)
I found that when I was autocrossing my modified SHO years ago, I never really adjusted the rears whether I was at an event or driving the car back and forth to work.. they were just set at 4/5 full stiff. I did change the fronts frequently though.
I was thinking it might be a good combination to have multi position adjustables up front but and the 'slightly stiffer than stock' rears.
Cost wise it would save $230 to go with that combination.. ($570 vs. $800)
Of course there are other combinations as well.. I'm more interested in peoples thoughts on combining the different brands / styles.
Old Mar 11, 2007 | 10:16 PM
champs65's Avatar
champs65
Old Mar 11, 2007 | 10:32 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
My .02 is, you might be able to make that work but it would take much trial and error to get it right, costing more in the long run.
Old Mar 12, 2007 | 11:36 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
As long as the non-adjustables are exactly what you want, I don't see why it wouldn't work.
Of course, if you can find rears that are perfect, you should be able to find front non-adjusts that are perfect, too.....and then you wouldn't need to spend the $$ there either.
The reason adjustable shocks exist is that finding perfect non-adjustable shocks is nearly impossible. If you can do it, then good on ya', mate.
Larry
code5coupe
Old Mar 12, 2007 | 11:48 AM
JEFNLSA's Avatar
JEFNLSA
FWIW...I paid $570 shipped for my QA1's (all four) from Jegs. This was a couple of months ago.
To Combining shock brands / types
