Convert to HID!
Old Mar 12, 2007 | 10:47 PM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
Default Convert to HID!
Heres the deal, this is for informational purposes only!
You can find a headlight housing that fits h4 bulbs on Ebay for about 20 dollars shipped
-This means instead of the light being sealed it takes a replaceable bulb, like a honda or a newer car.
Then you convert to HID, a kit runs about 250 bucks, and comes with a converter box, that runs a High Intensity Discharge bulb
-The kit comes with a little box that converts the amps or what not to allow bright lights like those on a BMW or a Mercedes or a C6.
-To install you just splice in the wires and your good to go, and it takes less electricity then factory
-There is no risk of burning up your car
I know these work because two of my friends got these kits on their cars and they look great, very bright, and it took us about two hours to do them right.
I am going to be converting to this system here in a month or so, so if anyone wants more info, i would be glad to help you.
Heres the little headlight that takes a replaceable bulb:
Its about 20 bucks, or cheaper it takes a H4 bulb
Here is what a HID kit looks like:
It runs around 250 or so, this is the one by buddies have
Just thought id let you know about this, just incase you are like me and want lights that actually light up the road lol
Old Mar 13, 2007 | 09:58 AM
CAP94's Avatar
CAP94
Keep us posted and take lots of pics when you do the install on your vette.
Old Mar 13, 2007 | 10:43 AM
sonomacrew01's Avatar
sonomacrew01
I looked into HID for my truck and found that installing a set of Silverstar ultras for $100 was bright enough. Difference was night and day with very bright white light. I intend to do the same for my corvette. I have also installed the same headlight on my corvette.
Old Mar 13, 2007 | 02:35 PM
rickneworleansla's Avatar
rickneworleansla
I'm very interested in doing this conversion also. I have the clear APC diamond casings already installed. I'm guessing these would work also. Was the HID kit bought on ebay also? So far most of the kits I have seen run around $400+. It would worry me that this one is only $250? Keep us updated as to how it goes + pictures. Good luck.
Old Mar 13, 2007 | 05:26 PM
PBnf's Avatar
PBnf
Please keep us posted. I really need brighter lights and have been considering changing to a plastic replacement type of light (weight savings). Having a much brighter light makes it even better.
Old Mar 13, 2007 | 06:12 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Old Mar 13, 2007 | 07:04 PM
serge's Avatar
serge
no, the kit comes from a company called, buyhid.com, they compile diffrent parts into the package, i dont think they actually make it, but ill let you guys know
Old Mar 13, 2007 | 07:14 PM
gator79's Avatar
gator79
try this
http://cgi.ebay.com/ebaymotors/ws/eB...m=170090163250
Old Mar 13, 2007 | 07:21 PM
serge's Avatar
serge
well im sure that works too, the only reason i said that company is because two of my friends have them on their cars and i know they work and how they look, but im sure there are cheaper ones out there that work just as good if not even better, so if anyone else finds some good ones, make sure to post them, so that when i do it, it will be cheaper
by the way those are bosch, so im sure they are way better then the ones i mentioned
Old Mar 13, 2007 | 07:29 PM
gator79's Avatar
gator79
thats what I thought cant go wrong with Bosch
Old Mar 13, 2007 | 09:05 PM
Ybnormyl's Avatar
Ybnormyl
I am confused about Hi Lo beams.
Do these lights change Hi Lo by the ballast altering "juice"?
Old Mar 13, 2007 | 09:21 PM
davidnclearlaketx's Avatar
davidnclearlaketx
Default HID's
I have been looking into the details and found this site useful.
www.xenon-hid-usa.com
This is what they replied to me when I emailed them asking about my vette:
All our kits are plug and play type, really not requiring cutting job. We have three kinds of H4 dual beam kit:
1. HID + Halogen (HID is for low beam)
2. Retractable - The bulbs can be moved forward and backward to generate dual xenon beams (HI/Lo), it comes with 2 ballasts;
3. Bi-xenon - it has 4 ballasts, there are two capsule in each bulb to control HI/Lo beam.
Check the Deluxe Edition , you can see ultra slim ballast, it's only half size and weight. This might help a lot with the room issue. Long 8cm, wide, 6cm. hig 1.5cm.
The bulb wire plus the wire on ballast, total is about 60cm long.
I've not purchased them yet but I'm planning on soon.
Old Mar 13, 2007 | 09:32 PM
davidnclearlaketx
I did do the conversion as serge said in the first post and I purchased the housings in light blue tint and they work great.
Old Mar 13, 2007 | 10:09 PM
C4Cvette's Avatar
C4Cvette
With those housings, the light is going to scatter all over the place, and you risk blinding oncomming drivers. The proper way to convert to HID is to use a housing that is made for HID's. In some states you can even get a ticket and also be held responsible for accidents caused by "impropper" equipment.
You might want to go with http://www.vette-hid.com/c4.html
I added these to my 1994 and love them. It took a bit of work to get them in, but they are so much better than the stock lamps. You also still keep the high beam.
Old Mar 14, 2007 | 12:04 AM
meshies's Avatar
meshies
^ got any closeups of the vette-hid setup?
Old Mar 14, 2007 | 04:31 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Looks like one more mod to add to the to do list.
Old Mar 15, 2007 | 12:26 AM
ubnpast's Avatar
ubnpast
actually there is a reflector next to the bulb, when you turn on the high beams it just is a magnet and moves... the bulb stays the same.
To Convert to HID!
Old Mar 15, 2007 | 02:13 AM
Mekanic's Avatar
Mekanic
Exactly, those housings are made for normal horizontal filament bulbs, whereas HID bulbs have a longitudinal filament . Causing the light produced to be improperly focused.
Either get housings made for HID, or get silverstars, or a HELLA H4 Conversion.
Old Mar 15, 2007 | 09:58 AM
rickneworleansla
hmm.... Payback for all those SUV's and Trucks that have been blinding me over the years.
Old Mar 15, 2007 | 07:46 PM
davidnclearlaketx
X2 !
I agree!!
