ground problem help 90' CPE
Old Mar 15, 2007 | 07:08 AM
elhefe's Avatar
elhefe
Default ground problem help 90' CPE
I am having a problem with my C4 horns. I have checked the fuses and relay and do not seem to find anything wrong. I cant seem to get the relay chassis out to check for voltage across the relay coil. What I can do is access the wire leader in the steering wheel. In this area I have a small metal leader that I assume (you know what happens when you assume) is always hot. With a meter on this to ground I have ) volts. This is what I think connects the coil to ground thus activating the horns. I activated the security system so I know the horns are good. When I short this leader to ground I do not get the horns to sound so I am thinking I am missing a ground. Does anyone have any idea how to troubleshoot this ground problem. I would appreciate any help on this. Thanks in advance. Steve
