Well, the C4 parts microfiche breaks down the parking brake info into 1984-87, 1988 and 1989-96. I can crosscheck parts numbers between the three for differences if there's one in particular that might answer your question. Let me know...
OK, well I checked on the parts number for the actual parking brake lever and the microfiche shows different part numbers for the 84-87 (14105127) and 88-96 (12529393). Hope this helps...
Wow thanks for the help! I thought I remembered hearing that they changed in the late 80s. Wonder if the mounting position is different for the carpeted door sills?
That I don't know. I've got a 96. It's a bit dark now but if no one comes along with a definitive answer before then, I'd be happy to take a pic or a measurement tomorrow...
The '88 and up style uses a smaller diameter bolt for the front mount. The '84-'87 has welded nuts inside the frame while the '88-'96 has pressed in nuts from inside the frame. This would definitely make it difficult to swap handbrake assemblies between the years or styles. Also the '88-'96 has a self adjuster for the calipers.
