Alarm
Old Mar 19, 2007 | 11:34 AM
robertt43's Avatar
robertt43
Default Alarm
After working on this 84 for about a year now,last Sat.,as I was backing into a spot,I shut off the car,set the electric locks {passenger lock didn't engage entirely,took a couple of tries} and then the ALARM went off,something I didn't even know worked,was now beeping the horn. I tried to restart the car,nothing. So I disconnected the horns,still nothing....What's up with that?.....Does the alarm only work in reverse?......I Jiggled the passenger slide lock,and then everything worked again....Car started and things are fine again......How can I disconnect this stupid alarm system forever?
Old Mar 19, 2007 | 01:24 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Might be easier just to fix the problem affecting the alarm. Door switches are fairly cheap. I had an aftermarket alarm installed recently and the passenger door switch created a big headache for the installer as it is the main door switch.
Old Mar 19, 2007 | 02:19 PM
robertt43's Avatar
robertt43
Thanks.......I think your right.....it was the passenger lock that did not engage correctly leading the alarm to think someone was jimming the door.......C F comes thru again....
Old Mar 19, 2007 | 08:39 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
http://forums.corvetteforum.com/show....php?t=1412968
To Alarm
