Problem at Storage Facility
Old Mar 28, 2007 | 02:16 PM
Lieutenant 804's Avatar
Lieutenant 804
I knew that I was just nver going to be happy at the old place, so
I did move out of the original place into another one that's much closer to my house so that I can keep an eye on what's going on. Also the new one has a south facing door to take advantage of some heat from the sun. In addition,I bought a huge tarp to cover the entire floor area of the space.
Thanks again for all the thoughts and input.
Old Mar 28, 2007 | 06:35 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
My diagnosis is the concrete was poured WITHOUT a VAPOR BARRIER under it.
Concrete by nature is LOADED with WATER but...............
Eventually the water will evaporate from the concrete. That can take 6 MONTHS depending on the local climate.
At that point moisture from the ground SHOULD be stopped by the VAPOR BARRIER under the concrete... that is IF there was a VAPOR BARRIER placed under the concrete before it was poured.
IF THERE WAS NOT............A L-O-T of water will FOREVER come up thru the concrete....forever and ever, Amen.
Old Mar 29, 2007 | 12:17 AM
z06Bigbird's Avatar
z06Bigbird
Not near Roswell, NM are you???
Take car out of unit. Let it sit in sun with windows down for about a week. At night, crack windows open unless weather is bad. Good chance of condensation inside of everywhere. You need to get that veh dried out.
Ed
