ignition coil
Old Mar 27, 2007 | 12:10 PM
bangand0lufsen's Avatar
bangand0lufsen
Default ignition coil
Just wondering how to replace the ignition coil on a 1993 corvette cause it apears to be stamped on to the braket?
Old Mar 28, 2007 | 11:00 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Perhaps the coil and bracket are replaced as one unit??
I dunno.....but I thought you should have at least one reply.
Larry
code5coupe
__________
I ain't easily impressed....
Old Mar 28, 2007 | 11:00 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Take the bracket off and the coil will come with it. The factory coil is riveted onto the bracket. You have to drill out the rivets and the new coil will come with bolts.
To ignition coil
