Insulation Help
Old Apr 2, 2007 | 05:42 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Insulation Help
In the process of installing new carpet in my 85. I haven't received my new mass backed carpet, but I assume that some of the existing insulation (matting) will be reused as it's glued in. Is there something I can use in place of this. The piece on each side of the leg room area is quite thick. Thanks.
Old Apr 2, 2007 | 06:16 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Nope, you remove all the old insulation, clean and scrape... Now would be the time to seal any leaks or spaces, install some sound and/or fireproofing material before you do the mass back carpet install...
As a side note, i did a Rino lining on my metal before installing sound & fire-proofing material, then mass back carpet... made a world of difference in sound and no air gaps...
Take your time, and do a search on carpet install, there's certain areas that you do first...
Try to save your old carpet to use as a template for your new install, there's always trim and cut - measure 3 times ; cut 1 time
Old Apr 2, 2007 | 06:52 PM
Cruisinfanatic
Thanks, that is what I was hoping. I did do some insulation as you sugested. I replaced the original with plastic backed 8 years ago. Faded terrible. The only good pieces are the front floor pieces on both sides. No noticeable wear or fade at all. Will probably see if there is a buyer for them soon. Mike
Old Apr 2, 2007 | 08:43 PM
vinnies87's Avatar
vinnies87
Mike: something to think about, if you plan to upgrade with new amp and sterio, you might consider running the wires and RCA connectors now makes for a clean install later..
One other thing i did, was run a new heavy duty ground (front & back) under the carpet, just in case ......
Old Apr 3, 2007 | 06:21 PM
Cruisinfanatic
Today I tore every piece of that fiber stuff out from under the console, sides of console, and under the dash. It looked like crap and it smelled. What can I use to replace this. I assume it's for heat and sound.
To Insulation Help
