fuel filter
Old Apr 2, 2007 | 10:17 PM
doggs31's Avatar
doggs31
Default fuel filter
change fuel filter 96 vette
Old Apr 2, 2007 | 10:18 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Double post: So whats your question ??- yes you can change a 96 fuel filter...
Old Apr 2, 2007 | 10:32 PM
RRT vette's Avatar
RRT vette
It's located on the passenger side, inside frame rail.
Old Apr 2, 2007 | 10:55 PM
Greg Gore's Avatar
Greg Gore
replacenent filter
2 "O" rings
16mm line wrench
20mm open end
10mm wrench for clamp bolt
pop gas cap to relieve pressure
be ready for fuel running down your arm. Will run down your arm until you have new filter in place and lines screwed in. Be sure you don't do it in a closed garage with a gas water heater nearby.
Old Apr 2, 2007 | 11:19 PM
93*Corvette's Avatar
93*Corvette
Huh????????????????
Old Apr 3, 2007 | 01:34 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Originally Posted by Greg Gore
replacenent filter
2 "O" rings
16mm line wrench
20mm open end
Pull the fuel pump fuse and run the car until it dies. This will get the fuel out of the lines so you don't have fuel running down your arm and into your armpit which burns like hell. I would also pop the gas cap.
Old Apr 3, 2007 | 08:14 AM
runner140*'s Avatar
runner140*
If or how?
Old Apr 3, 2007 | 01:23 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
not yet
Larry
code5coupe
__________
I ain't easily impressed....
Old Apr 3, 2007 | 08:13 PM
caa5030's Avatar
caa5030
"K-mart, I can only buy my boxers at K-mart"-Rain Man
Thought I would just add some more nonsense in here.
Old Apr 3, 2007 | 08:20 PM
aminnich's Avatar
aminnich
Yes, it is more fun than a root canal, but just barely.
To fuel filter
