Hood Release Issues
Old Apr 4, 2007 | 05:29 PM
murraybob's Avatar
murraybob
Default Hood Release Issues
I tried to release the hood while the car was parked in the garage, and the pull was extremely hard (the first time) but it finally released anyway. I checked the oil and dropped the hood. I then decided I wanted to check the hood release to make sure it was OK. That time I could not get it to release at all. (the pull on the release handle felt very stiff) I thought 'Oh No, I haven't provided an emergency hood release for that situation. (recommended many times on this site)'
The next day I pulled the car out of the garage, and in the drivway the hood release worked just fine. I suspect that while it was in the garage I had the right front tire up on a 2x4 that was laying on the floor right next to the car, and that twisted the frame enough to jam the hood mechanism. That would be another example of the lack of frame stiffness characteristic of the C4s. Oh well.
I decided I had better provide an emergence release in case the release cables do give me problems down the road. I took extra long nylon wiring zip ties and tied them around the release lever under the hood and fed the ends to lay under the wiper blades. I tested it out and it seems to work very well. That setup is not as sturdy as some have described, but it was extremely quick and easy to do. (2 min)
If I do lose a cable I may need to do something more sturdy, but this will allow me to get the hood open on an emergency basis.
Old Apr 4, 2007 | 06:15 PM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I learned this awhile back from Mr.Mojo. Haven't had to use it yet but it's nice to know it's there Thanks Frank
Old Apr 4, 2007 | 07:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I've recently read of several versions of this "trick" and think that maybe this spring it will be one of my projects...
Old Apr 4, 2007 | 08:12 PM
murraybob's Avatar
murraybob
Exactly!!
Old Apr 4, 2007 | 08:33 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Sorry its so big, but the best to see how i did mine a couple of yrs ago... haven't had to use it yet, but safe to know they are there, did to both sides
To Hood Release Issues
