shift boot screws
Old Apr 7, 2007 | 12:44 AM
CE1's Avatar
CE1
Default shift boot screws
Has anybody replaced the shift boot ( '96 manual ) ? What did you use to reattach the boot to the shift plate, would like to use new if possible and not pull old out of plate. TIA
Old Apr 7, 2007 | 07:26 PM
DaveN355's Avatar
DaveN355
I didn't change the boot, but when I changed the console, I did remove the boot from it. As I remember, the screws were nothing special (I did reuse the original ones), but you need to remove the metal caps that the screws thread in. I used a thin flat screw driver to pry up the sides a little and used a larger screwdriver to pry them off. You have to squeeze them a little before putting them back on.
Hopes that helps some.
Dave
