problem w/ hood latch
Old Oct 15, 2001 | 04:06 PM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
Default problem w/ hood latch
ok my passanger side of the hood will not latch shut. I pulled the latch off to look at it and it seems to be working correct so I cant figure it out.
Old Oct 15, 2001 | 04:28 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: problem w/ hood latch (MBVette)
Scott:
There is a rubber bumper up by the latch mechanism. It is adjustable for height by turning a screw that is threaded onto it. The stop is round and made of black rubber. Lower it a little at a time untill the hood closes. Make sure that your release cables are working exactly as they should before doing the adjustment. Don't ask !
:seeya
Old Oct 15, 2001 | 04:30 PM
C4 Suke's Avatar
C4 Suke
Default Re: problem w/ hood latch (Mark 84ltblu)
Thanks, I had the same problem , and I think it caused crack marks in my hood.
Old Oct 15, 2001 | 04:54 PM
MBVette's Avatar
MBVette
Default Re: problem w/ hood latch (C4 Suke)
ok I tried to move that screw and it is in there good. I even tried WD40 and still wont move. Is there some kind of secret to doing this?
Old Oct 15, 2001 | 05:29 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
It is held in place with a set screw. You have to loosen the set scrw before you can move the rubber bump stop. Use small increments when adjusting and do not loosen too much or it will rattle (sounds like squirrels under the hood). Make sure you tighten the set screw back after final adjustments.
Just to make sure you are closing the hood correctly...are you dropping the hood from the top of the windsheild (12").
[Modified by Vette92, 3:30 PM 10/15/2001]
To problem w/ hood latch
