Need some advice
Old Apr 8, 2007 | 01:15 PM
Rocket22's Avatar
Rocket22
Default Need some advice
I am replacing the halo weatherstripping and have most of the old stuff out. What is the best way to get out the glue without using a torch or chisel? DOes it all need to come out? It is getting close to summer and am actually replacing this on two tops. ANy experience would help.
Also, the four screws under there? WHat is removed when those are taken out?
Old Apr 8, 2007 | 01:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Defintely not a torch or chisel, 3M makes a product that works pretty well, check your local auto paint supply. Make sure it all comes off-
Old Apr 8, 2007 | 05:14 PM
bogus's Avatar
bogus
the chemicals work, so would a dremel tool with a steel brush.
Old Apr 8, 2007 | 05:23 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
3M adhesive remover should do the trick.
Old Apr 8, 2007 | 08:17 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
but make sure and get the STAINLESS brushes that Dremel makes, the ordinary steel wire wheels get eaten up in no time.
To Need some advice
