Climate control question
Old Apr 9, 2007 | 08:07 PM
cyclist7531's Avatar
cyclist7531
Default Climate control question
Quick question. I noticed the other day that when I started the car the led over the OFF button on the automatic climate control would flash briefly and then stay on solid. I've check the AC and it seems to put out a good deal of cold and the heat seems to work as well. So, I'm not sure what the flashing LED over the OFF button means. This is on a 91 with automatic climate control.
Thanks, mark
Old Apr 9, 2007 | 08:14 PM
HG's Avatar
HG
Don't know the answer, but it may have set a code in the CCM. Here is some info how to check for codes. http://www.c4guru.com/articles/CCMCodePull.pdf
Old Apr 9, 2007 | 09:52 PM
Travis93's Avatar
Travis93
Check this one out too.
https://www.corvetteforum.com/techti...=193&TopicID=2
I have seen a better write up but this is the one I could find and it has all the information just a little harder to understand.
To Climate control question
