Headliner How to do?
Old Apr 10, 2007 | 05:20 PM
zeus's Avatar
zeus
Default Headliner How to do?
I need to do a headliner for my Painted top. Has any one done this befor. If so how hard was it.
Old Apr 10, 2007 | 06:02 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
It's a piece of cake. Just buy the material and go at it.
Old Apr 10, 2007 | 06:32 PM
EvanD's Avatar
EvanD
CF Community Team
I pulled the old material off sanded the pad lightly to remove loose particles, cleaned the old cloth to remove loose particles. Sprayed the pad witn 3M 77 adhesive and layed the original cloth back on, worked great, looks new, and even though people on here said it would fall down it still looks perfect more than a year later...
Old Apr 10, 2007 | 11:17 PM
tinman332's Avatar
tinman332
It was pretty easy. Pulled the old material off and bought new vinyl at the fabric store. Cleaned all the loose particles off the foam. I tried using the spray adhesive but didn't like how it held so I used the caulk type adhesive and spread on thoroughly and real smooth. Then laid the fabric over it and spread it, stretched it, and smoothed it across. Kept on burnishing it for good contact then let it set hard. push the edges in as much as possible. Then trim the edges with a utility knife and that's it! Looks great and feels great!
Old Apr 11, 2007 | 11:17 AM
SteelBlue90's Avatar
SteelBlue90
Hardest part I encountered was getting the old headliner board out of the top without damaging it. Take your time,,, easy, inexpensive fix per the directions already stated.
Old Apr 11, 2007 | 05:50 PM
ps374's Avatar
ps374
Yep I did the same on my 84, the factory cut is perfect and you can trim it and tuck the excess materal with a straight edge in the seam.
To Headliner How to do?
