map sensor wire help
Old Apr 13, 2007 | 11:49 AM
excessive81's Avatar
excessive81
Default map sensor wire help
i took my 90 l98 apart to redo the intake gaskets. but it seems like the car has ate the wire to the map sensor on the intake plenum. i have pulled the distributor back out looking for it and i dont see where it is anywhere. so i need some help finding where it should be running from. i am positive it came from the distributor area when i took it apart but i sure dont see it anywhere in the engine compartment let alone where i thought it to be. also on the distributor install i put the red wire to battery positive and brown to tach. pretty sure that right but tach not working now
thanks
shane
Old Apr 13, 2007 | 11:54 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
check the FSM
Old Apr 13, 2007 | 11:56 AM
excessive81
fsm? what that factory service manual....never mind
To map sensor wire help
