Brake bleed sequence
Old Apr 18, 2007 | 10:13 AM
JackVM's Avatar
JackVM
Default Brake bleed sequence
Is there a proper sequence for bleeding brakes on a C-4, such as left front first, then left rear etc? Thanks.
Jack
Old Apr 18, 2007 | 10:20 AM
KCHOTBOAT's Avatar
KCHOTBOAT
Jack
RR(passenger side) first, LR, RF and LF.
Old Apr 18, 2007 | 10:58 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Depends on year
On later cars you bleed the abs behind the driver seat first
I would HIGHLY recommend you get a service manual
Old Apr 18, 2007 | 12:16 PM
jhammons01's Avatar
jhammons01
Furthest away always. I may not be 100% correct for all cars but of the many I've had to bleed....and while using this Technique...I've never had to re-bleed any lines.
Most of the time people aren't patient enough on the Passenger Rear for all the Air to come out. That fluid should look clear and new before you even begin to think about closing the valve for good.
think of it as "flushing" the system rather than Bleeding the brakes and all will be good. All it will cost you is a $5 in fluid
Old Apr 18, 2007 | 12:21 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Most people will tell you to start with the wheel furtherest away, then work your way "closer".
In all actuality, however, the sequence does not matter.
I've done it fronts first several times and have gotten a good flush/bleed.
It's not nearly as important as the order in which you remove your spark plugs...
Larry
code5coupe
__________
I ain't easily impressed....
Old Apr 18, 2007 | 12:29 PM
kalister1's Avatar
kalister1
I am not sure about the Vette but every other car I ever worked on had 1 line that fed the rear with a T fitting on the axle housing(IE: solid axle cars) Whichever side you do first will flush out the main line and then the other side only has to flush from the T fitting. I flushed my 93 coupe(It's a Ruby) out with a Quart of brake fluid, more to change fluid than bleed out air, I did not pay attention to the line/s that run to the rear of the car. But any way it does not matter.
Old Apr 18, 2007 | 09:27 PM
JackVM's Avatar
JackVM
Thanks, I have a complete service manual, however I don't find where it mentions the order to bleed. I'll try the furthest technique first and see if that works. Thanks all.
Old Apr 19, 2007 | 05:03 PM
rocco16's Avatar
rocco16
It will work just as well as going with any other sequence.
BTW, the fact that the sevice manual doesn't recommend any specific sequence should tell us all something...................
Larry
code5coupe
____________
To Brake bleed sequence
