alternator problems need Helpppp
Old Apr 18, 2007 | 03:56 PM
92lt1vet's Avatar
92lt1vet
Default alternator problems need Helpppp
hey guys, after doing my tune up and everything was back together i noticed i had lost the bracket from the back of the alternator that mounts over to the intake. ever since than ive had a charging problem with the car. Is that meant as some sort of ground or is that just for support? Also i just added hypertech pulleys should i put the stock alt pulley back on do you think that might be the problem? thanks mike
Old Apr 18, 2007 | 06:57 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Bracket is support only, and a critical support piece. Your charging issue is due to the hpertech pullys, go back to stock
Old Apr 19, 2007 | 11:04 AM
92lt1vet's Avatar
92lt1vet
Default thanks
Hey thanks for the advice Vinnie ill have to try to find one now
To alternator problems need Helpppp
