'87 code 33.
Old Apr 19, 2007 | 01:53 PM
DaleD's Avatar
DaleD
Default '87 code 33.
Coming to work this morning, my car almost completely stalled out on me. I was coming up a hill, and it hesitated, then bogged, big time, no power. I let off the gas, pushed it to overdrive, it stumbled, but picked up and got me to the top. I put it in drive and got to work, about 2 more miles.
I went home for lunch, and it ran very well. Go figure. I pulled the codes by jumpering pins A and B. I got a 33. That translates to MAF, vaccuum lines, or bad ecm.
Ever since the weather got a little better, this car hasn't run quite right. It runs great when it's cold outside. It also runs pretty good once the car warms up, all the way. But I've noticed it idles rough when started, and will hesitate or bog down on acceleration, sometimes.
I'll do a visual inspection of hoses tonight, but what else can I check myself?
Old Apr 19, 2007 | 02:01 PM
vader86's Avatar
vader86
http://members.shaw.ca/corvette86/Code%2033.pdf
Old Apr 19, 2007 | 02:38 PM
DaleD's Avatar
DaleD
The document talks about a fused jumper. I can make one, aligator clips and wire soldered to a fuse holder. But, what size fuse?
Old Apr 19, 2007 | 04:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
'87 code 33.
=MAF reading too high.
Try changing out the MAF power relay and clear the code.
If it comes back pick up a used MAF from a mid-'80s F-body car to swap in.
Old Apr 19, 2007 | 05:13 PM
DaleD's Avatar
DaleD
The code description says, MAF, vaccuum lines, or ECM.
Doesn't the IAC have something to do with this too? Just one relay on the 87 to swap out?
Old Apr 19, 2007 | 05:51 PM
Uriel's Avatar
Uriel
I had the same symptoms and code a few weeks ago and a new MAF power relay sorted it a treat.
Old Apr 19, 2007 | 05:56 PM
DaleD's Avatar
DaleD
"sorted it a treat"? Must be a British thing? Does that mean it fixed it?
Old Apr 19, 2007 | 06:20 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
sometimes it does, you can also swap the relays and see if that code goes away, then get new relays, about $20 each at NAPA, and both are the same part no
Old Apr 19, 2007 | 06:45 PM
DaleD's Avatar
DaleD
I have a cooling fan relay, is it the same relay?
Where are these relays located? I went and checked out the MAF, and the connector wires run into a plastic conduit, and from there I can't tell where the relay is. I want the power relay, not the burn off relay, right?
Ok, I found the relays, they are behind the battery. Which one is power, which is burn off? They're the same? Is it reasonable to just shotgun and swap both?
I went out and checked the two of them out. I can't tell which is which, but it looks like there's enough slack to swap connectors on the 2 relays. That is, IF I could figure out how to unplug them. Do I have to unscrew the bracket holding the 2 relays so I can get a good grip and pull the connectors out? Or, how do I get them out? I'll give GM credit, they're definately securely fastened.
Old Apr 19, 2007 | 07:16 PM
RRT vette's Avatar
RRT vette
That code is usually thrown when the ECM recieves a signal out of it's range for a set number of seconds. The burnoff relay is facing toward the passenger side and the power relay is facing forward. If you follow the link that was provided by vader, it will lead you to the correct way to fix the problem. The code does not mean the relays are bad. It could be a wiring or connection issue at the relays, MAF sensor, or ECM. I would highly advise to troubleshoot from the link above, to save the most money and time. The relays are the same, but unsure of the fan relay being the same. Good luck.
To reset the ECM, disconnect the neg cable to the battery for ~ 30 seconds.
Old Apr 19, 2007 | 07:25 PM
DaleD's Avatar
DaleD
I have stored codes, but it's not throwing them constantly. If I were to go out right now and work on it, I'd be trying to fix a car that's working. It's a great document, other than it doesn't specify the value of the fuse for the fused jumper.
Old Apr 19, 2007 | 07:41 PM
RRT vette's Avatar
RRT vette
If you read carefully on the link, it tells you exactly what to do and also gives wire colors for each individual circuits.
First, disconnect the battery as stated above. Reconnect and start the engine. After ~ 1 minute IF the SES light comes on, then turn the engine off. Use a 12-14 ga jumper wire, (preferably one with a 10 amp fuse since the fuel pump circuit has a 10 amp fuse), and connect one end to the pos side of the battery and the other into terminal G of the ALDL (bottom left terminal). This will send battery voltage to the fuel pump circuit and also a few other circuites. Then follow the chart until you find the problem. If you print the link, it will take you all of 30 minutes to find the culprit. Let us know how it goes so we can help.
Old Apr 19, 2007 | 08:28 PM
65Z01's Avatar
65Z01
Since both relays are likely about 19 yrs old it wouldn't hurt to replace them both.
To reset the codes I like to open the connector in the Orn wire near the batt pos terminal for a copla minutes. This drops power to the ECM w/o effecting the presets of the radio, clock, etc.
Old Apr 19, 2007 | 09:12 PM
RRT vette's Avatar
RRT vette
Yep, there are a few different ways to reset the ECM. Pulling the ECM fuse works too.
To '87 code 33.
