Driveway fun
Old Apr 21, 2007 | 04:37 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Driveway fun
I used the tech articles at www.c4guru.com to drain the ZF6 and refill it with GM Syncromesh Transmission oil. I then drained the Dana 44 and added Royal Purple and GM positraction additive.
Neighbors think I am crazy. I dumped half a bottle of the tranny oil in the driveway and it also soaked my hair. Good thing I bought plenty.
I just love washing my hair with Fast Orange.
Old Apr 21, 2007 | 05:27 PM
moore299's Avatar
moore299
It looked like another beautiful day outside to be catching up on some of those little things we've all put off until nicer weather.
I know I've got several.
Old Apr 21, 2007 | 05:30 PM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
Excellent!
Notice any seat-of-the-pants difference?
Old Apr 21, 2007 | 10:52 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Originally Posted by Chance
Excellent!
Prolly not much, but I'll bet his comb goes thru his hair quicker!
Old Apr 21, 2007 | 10:57 PM
90 Convertible's Avatar
90 Convertible
He also doesn't have to worry about dandroff now
Old Apr 21, 2007 | 11:09 PM
corvetteronw
Cruise-In VIII
Excellent!
I went took it to a local cruise spot about 30 miles away and met up with some of the W Michigan Forum members. It seemed to shift smoother. No leaks as I looked under it at the show to make sure.
Tomorrow I will clean the throttle body, clean and re-oil the K&N air filter, and check for debris between the radiator and AC evaporator. I also plan to install my new Hurst cue-ball shift ****.
I had a check engine light come on this winter during one of my warm up sessions. I cleared the code by disconnecting the battery but it came back a few miles down the road. Anyone know where the ALDL connector is on a 96 (looks like the 94-96 have the same style connector)?
Old Apr 21, 2007 | 11:11 PM
90 Convertible
ALDL connector should be attached to the drivers side knee panels.
Old Apr 21, 2007 | 11:17 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
And to the left of the steering column.
Old Apr 21, 2007 | 11:38 PM
Gonzo's Avatar
Gonzo
I guess you are officially a Royal now, you magisty
Old Apr 21, 2007 | 11:44 PM
Gonzo's Avatar
Gonzo
Can you add royal purple to both the ZF6 and the rear diff????
Old Apr 22, 2007 | 12:21 AM
Chance's Avatar
Chance
St. Jude Donor '08
Clean and oil the K&N filter tonight, and reinstall it tomorrow after it dries.
Old Apr 22, 2007 | 03:07 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I do believe Royal Purple makes a compatible ZF6 fluid. But don't use the rear diff lube in the ZF6. It's not the same stuff.
Old Apr 22, 2007 | 03:34 AM
VetteTech81's Avatar
VetteTech81
I can relate, I've had many baths with ATF ect.... my neighbors think I'm crazy (only a few) because I bought a lift for the garage..
-=Rick
Old Apr 22, 2007 | 11:16 AM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
Hey Ron-
Great project! When your car is on jack stands do you not leave the doors and hood open? I know when you either raise or lower it they should all be open but I was not sure about being on stands....
I just ordered front shocks and some caliper paint to work on the 92 this week, I hope!
PS- I heard some 93 octane also works well on cleaning grease and oil out of human hair! Now I know why I shave all mine off!
Last edited by wmupaprmkr; Apr 22, 2007 at 11:17 AM. Reason: another random thought, bored at work!
Old Apr 22, 2007 | 11:23 AM
corvetteronw
Cruise-In VIII
I was in a Chris Petris C4 class. He said to not bother with opening the doors when lifting. It is an urban myth. Someone is the class said he knew of a coupe owner who lifted their car with the doors open and the body twisted and cracked the glass top. Verts have an X brace that lessens the twist so I don't worry about it.
I'm sure everyone has there opinion.
Old Apr 23, 2007 | 10:44 AM
wmupaprmkr's Avatar
wmupaprmkr
Always good to know. Thanks!
Are you saying you vert guys are better than us coupe guys???
Old Apr 23, 2007 | 11:02 AM
jrp's Avatar
jrp
On my LT4, and probably Ron's, it is to the right of the steering column.
To Driveway fun
