Help!!!! CD won't eject
Old Oct 17, 2001 | 11:18 PM
Flylow's Avatar
Flylow
Default Help!!!! CD won't eject
The Bose in dash CD player in my 92 won't eject a disc. I've pushed all the buttons and turned it off and on many times. The radio won't play either. How do I get the disc out?
Old Oct 17, 2001 | 11:33 PM
Hi-yo-Silver's Avatar
Hi-yo-Silver
Default Re: Help!!!! CD won't eject (Flylow)
Mine did the same thing, so I held the eject button in for 15-20 seconds and it finally puked :U it out. :flag :flag :flag
Old Oct 18, 2001 | 12:01 AM
blue88vette's Avatar
blue88vette
I had a sony once that crapped out. When I would push eject, I could hear the motor trying to push it out, yet it wouldn't spit it out. So what I ended up haveing to do, was slide another disc in at an angle, so that it slid under the edge of the cd that was stuck, and then use the second disc as a lever to lift the cd, and pull it out. I would recommend that if you do this, you use a blank cd-r, or an old cd you don't listen to anymore, because it can scratch them.:nono: Especially since cd's cost around $15 a pop nowadays. :sad:
Old Oct 18, 2001 | 12:17 AM
moffitt's Avatar
moffitt
Thats the first sign of a soon dead CD player.
Old Oct 18, 2001 | 12:42 AM
McShagger's Avatar
McShagger
Here is what you do. Get a butter knife(Make sure it has no jagged edges.) Then spread some rubber cement over one side of the knife. Stick thi knife in the CD portal so that the rubber cement is facing downwards. Try to make the CD stick to the kinfe then lift up and out. Its that simple. :D
Old Oct 18, 2001 | 05:49 AM
pablocruise's Avatar
pablocruise
Also do yourself a favor and replace that Bose crap.
Old Oct 18, 2001 | 08:06 AM
CowboyNVette's Avatar
CowboyNVette
Default Re: Help!!!! CD won't eject (89 Paul in cal)
I kinda like that Bose Crap. Maybe I'm not as much as a music buff as some of you but mine seems pretty good to me :rolleyes: at least its good enough for me.
Old Oct 18, 2001 | 09:52 AM
Mylzi's Avatar
Mylzi
Help Corvette ate my CD ... :D :D :D
That Bose player is not good..
Old Oct 18, 2001 | 09:15 PM
OcalaGuy's Avatar
OcalaGuy
The Blows player is NOT our friend.
Old Oct 19, 2001 | 03:43 AM
Ruby_Roadster's Avatar
Ruby_Roadster
Make sure the unit is off - then press the Eject button, has always worked for me when the CD gets stuck.
Old Oct 21, 2001 | 12:40 PM
BJ's Avatar
BJ
I had the same problem about two years ago - you can use a credit card, another cd, or some other thin and flexible piece of plastic to lever the stuck cd up so that the radio can eject it. Before you throw the Bose in the trash make sure that it's not the cd that's the problem - I was ready to pull my radio until someone on the forum gave me that advice. There was nothing wrong with the Bose, it was just the one cd that was bad.
Bob Johnson
92 6spd coupe
Old Oct 21, 2001 | 11:55 PM
Silver 96's Avatar
Silver 96
Default Re: Help!!!! CD won't eject (BJ)
I had a problem with a CD my son recorded. I think it was because of the stick-on label hanging up, although there were no loose edges.
I made a rule: no stick-on labels - no problems since then.
Old Oct 22, 2001 | 12:58 AM
GTs 58's Avatar
GTs 58
Default Re: Help!!!! CD won't eject (Silver 96)
Once it eats the CD, the player is shot. With my 90 and the 94, I've had 13/4 years total playing time on the CD players. :mad
To Help!!!! CD won't eject
