"89 dash cluster
Old Apr 25, 2007 | 05:15 AM
Puna's Avatar
Puna
Default "89 dash cluster
I am about to enter the interior "phase"of the "89 re-build,The gas guage and oil pressure are dark on the cluster, I am considering an exchange with Corvette Parst Service Co. any one have experience with them, good or bad,
Old Apr 25, 2007 | 09:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
No experience with those shops but have you replaced the bulbs & cleaned the cluster contacts??
Old Apr 25, 2007 | 09:26 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Check the two upper bulbs (behind the chrome buttons).
Old Apr 25, 2007 | 09:32 AM
03whitecoupe's Avatar
03whitecoupe
I've had to send mine in 3 times to Gene Taber and have had mixed results. My problem was his "fix" didn't last and I had to return it a couple more times to get it right. Hopefully, it's my last time having to do that
Here's his website:
http://www.corvettedashclusterservice.com/Ordering.html
Old Apr 30, 2007 | 04:17 AM
Puna's Avatar
Puna
I was considering a trade in for a rebuilt, do you know wht that turn around time is
Old Apr 30, 2007 | 04:20 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
The dash in my old '89 had a dark spot too.
Real annoying.
But if the displays all work properly and it's just darken, it may not need to be sent off for repairs.
Like the others above said, it might just be a burnt out bulb.
Old Apr 30, 2007 | 01:04 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
There is a guy on ebay that sells each of the 3 pieces individually as new units for like $100/ea I hear. I need a new center gauge section, all my started bleeding a month ago. I can't even read the gas gauge anymore
I will see if I can find the seller or company that is doing this. My bro-in-law replaced some on his 84 with newer ones on an 85? or something, all new units and all work flawlessly.
Old Apr 30, 2007 | 08:40 PM
ffvetteman's Avatar
ffvetteman
If it has just got a dark spot you have a bul or 2 out.
Pull the cluster, pry off the round silver things, under each is a bulb. 4 total. Replace the bulbs.
A few cents or a few hundred dollars.
Old Apr 30, 2007 | 09:09 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You don't need to pull the cluster, just remove the plastic bezel in front of it. Remove the headlight **** and tilt lever.
Old May 1, 2007 | 01:36 PM
TaylorMutts's Avatar
TaylorMutts
I bet this is the guy who sold those LCD panels:
http://cgi.ebay.com/ebaymotors/84-89...QQcmdZViewItem
I bought two from this guy--a great value and easy to install. He even provide some tech assistance when I made a boo-boo on the install.
He has all of the LCDs--if he does not have the one you need listed for sale on eBay, just send him a note and he will sell one direct. I highly recommend this seller.
Old May 8, 2007 | 10:46 AM
anesthes's Avatar
anesthes
Neat. My digital dash is a little goofy. I got tach digits out, scale bars missing, etc.. I hate the digital dash. I want to throw it in the trash.
I wish there was a direct-replacement aftermarket analog dash.
-- Joe
To "89 dash cluster
