removing the bow
Old Apr 25, 2007 | 04:40 PM
gbnoll's Avatar
gbnoll
Default removing the bow
Is anyone aware of any how to articles on removing the bow from my 94? The manual is not real helpful on this issue.
Old Apr 25, 2007 | 08:58 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
You may want to be more specific, do you mean the bow in the convertible top?
Old Apr 26, 2007 | 01:31 PM
gbnoll's Avatar
gbnoll
No, maybe I am calling this the wrong name. I am trying to remove the piece that sets over both rear quarters and runs between the targa top and the rear glass on a coupe. Someone had repalced one of the quarter panels and it is not appropately finished where the top of the quarter fits up under this "bow". If it would help I may be able to post a picture.
Old Apr 26, 2007 | 02:23 PM
thebeerman's Avatar
thebeerman
You mean you got it for Christmas and you are just taking the wrapping off?
Sorry, couldn't pass that one up...
Old Apr 26, 2007 | 02:27 PM
80sRule's Avatar
80sRule
I think you are referring to the halo?
I thought that was bonded to the car.
NEVRL8T's Avatar
NEVRL8T
I think he means the "halo".
Old Apr 26, 2007 | 03:43 PM
Muffin's Avatar
Muffin
If this is correct,then 80s is correct. Doesn't come off.
Old Apr 26, 2007 | 11:48 PM
Mr Mojo's Avatar
Mr Mojo
If it's the halo as others have pictured, it's not removeable. If you mean the interior portion, there are some hidden screws behind the lights on both sides.
Old Apr 27, 2007 | 10:15 AM
Bigredwing's Avatar
Bigredwing
I would have called it the "B" pillar but "halo" works. First new thing I learned today!
Old Apr 27, 2007 | 11:03 AM
mikey whipreck's Avatar
mikey whipreck
Sure it does. Just not easily. I took it off of my '85.
It requires a few things.
-A strong heat gun.
-A whole lot of patience.
-A relatively skilled hand in bodywork.
They are glue/bonded to the car with standard SMC bonding adhesive (I used SEM 3887 to rebond it- at least I think that was the number, its been over a year) . They are glued at that lip, and a strand along the front side of the halo (which would put it under the weatherstripping), and what I can best describe as a "loose" strand along the back-side of it underneath where the hatch glass is bolted into place.
This is a pretty major undertaking, and the better you are at it, I would guess the longer it will take. I used a lot of different tools to pry that halo loose after the heat gun had done its work. (once you see smoke coming from underneath it and smell the glue, that means it's probably ready to be worked loose). I pried it loose with wood chisels, body putty scrapers, flat blades, anything that I could use to fit in a small area, and not put too much pressure when prying...
Did any of that rambling mess help?
good luck
Old Apr 27, 2007 | 12:55 PM
gbnoll's Avatar
gbnoll
Yes that helped quite a bit. It goes to the body shop asap. Thanks for sharing your expirience.
To removing the bow
