need help
Old May 1, 2007 | 07:59 PM
c5joey's Avatar
c5joey
Default need help
how to change battery in my friends 96 c4
Old May 1, 2007 | 08:15 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Look for 10mm bolthead in the seam under the drivers side fender gills. This has to be loosened using an open end wrench.
Then there's a bolt on the top right holding the panel in , and some torx bolts on the fender liner.
Remove all these and the panel will slide off and you can get to the battery. (The bottom bolt just gets loosened, not removed)
Old May 2, 2007 | 09:37 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
To need help
