Tranny problem
Old May 4, 2007 | 04:14 PM
95!Vette!'s Avatar
95!Vette!
Default Tranny problem
Well today I left to go to work, and noticed when I turned my car on it sounded funny, anyway I went to put it in reverse and it shifted hard hmmm I thought that nothing major, well went to put it in drive and pressed the gas and the car would not shift in gear the rpms just kept going up I slowed down and gave it some more gas and it did the same thing. Does anybody know whats wrong Im thinking my transmission just went out on me?
Old May 4, 2007 | 04:27 PM
Pete K's Avatar
Pete K
Did you have no forward gears or did it not shift out of first gear into second gear
Old May 4, 2007 | 04:28 PM
All2kool's Avatar
All2kool
Years ago I had a '72 Cutlass that did that - could only drive it in reverse. I kept getting farther and farther away from home. I still can't remember where I left that car.....
Old May 4, 2007 | 04:36 PM
95!Vette!'s Avatar
95!Vette!
yeah I had forward, but it wouldnt shift in second gear the rpms just kept going up, and it shifted very hard in reverse for some reason.
Old May 4, 2007 | 04:46 PM
Pete K's Avatar
Pete K
It could be many things ranging from a solenoid or valve stuck in the valve body.It could also be a broken band, band anchor, sunshell etc.
You need a pro. The fact that has reverse eliminates the torque converter and blocked filter.
Old May 4, 2007 | 04:48 PM
Pete K's Avatar
Pete K
I am going to go out on a limb and guess that it is a broken reaction shell. Sometimes this is called a sunshell also.
Old May 4, 2007 | 04:55 PM
95!Vette!'s Avatar
95!Vette!
So is this something That I can fix or do I need to take it to a corvette specialist?
Old May 4, 2007 | 05:07 PM
jeffyc's Avatar
jeffyc
pete wouldnt a broken sun gear shell (reaction shell) make it have not reverse?
Old May 4, 2007 | 07:30 PM
Muffin's Avatar
Muffin
I don't know about a Corvette specialist but you do need a knowledgeable transmission specialist.
Old May 4, 2007 | 11:35 PM
Pete K's Avatar
Pete K
Yes. I was thinking that was the loud bang he described.
Old May 5, 2007 | 12:52 AM
bogus's Avatar
bogus
It might be smart to pull the thing out, box it up and send it up to Nanticoke, PA.
Old May 5, 2007 | 01:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What if it simply makes a loud screeching noise on occasion when shifting into reverse?
Old May 5, 2007 | 11:23 AM
daca's Avatar
daca
Good one!!
Old May 5, 2007 | 02:04 PM
95!Vette!'s Avatar
95!Vette!
What is going on here I just went to drive my car today and it shifted fine what the heck is going on, What would cause it to do that ?
Old May 5, 2007 | 02:10 PM
redwing76's Avatar
redwing76
Didja check the fluid level? Have you had it changed lately?
Old May 5, 2007 | 02:27 PM
95!Vette!'s Avatar
95!Vette!
Nope I bought the car a couple of months ago, but never have changed the tranny fluid, I checked the fluid yesterday and it seemed to be fine at the right level was brownish red looking.
Old May 5, 2007 | 03:14 PM
Pete K's Avatar
Pete K
That is good news. Hope for an intermittant solenoid problem. It is a best case problem
Old May 5, 2007 | 08:36 PM
redwing76's Avatar
redwing76
Get it serviced right away.
Old May 6, 2007 | 01:17 PM
95!Vette!'s Avatar
95!Vette!
YES SIR!!
To Tranny problem
