Rear Hatch struts
Old May 6, 2007 | 03:43 PM
jabez's Avatar
jabez
Default Rear Hatch struts
Looks like I am gonna have to replace mine (no hurry).
Just wondering how tough a job it is? Is it just a bunch of screws and bolts?
Old May 6, 2007 | 04:06 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Neither, they just snap onto the mounting studs. Ball and socket type connection. There is a little clip thing you slide open to allow the strut to snap over the ball.
Old May 6, 2007 | 08:20 PM
jabez's Avatar
jabez
Old May 6, 2007 | 08:33 PM
bryantbjb's Avatar
bryantbjb
Real easy and I'm not mechanic.
Have someone hold the back glass - one used strut will not hold it - trust me I know.
Disconnect the rear defrogger pins.
Use a flat heat screwdriver to pull the small metal clip on each end. One end at a time. The strut will but pull away from the mount.
The new struts will just snap into place.
Easy - should take about 20 minutes.
The back glass is really heavy and it really hurts when it lands on your head.
Old May 6, 2007 | 08:57 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
One used strut = divot in skull
Old May 6, 2007 | 09:48 PM
J1corvette's Avatar
J1corvette
Not a bad job at all, the way Bryantbjb replied is how it's done. I did mine in about 30 minutes. I used a paint pole to hold up the glass because there was no one around at the time. After I replaced one strut I took the pole out and the glass came down but not fast so I was able to catch it before it got me. You need to replace them both before letting the glass go.
Old May 6, 2007 | 10:22 PM
Dads90's Avatar
Dads90
Just verify you take home a left and right. Got two lefts and they didn't have the right. So I replaced the left. It still pops open like its supposed to.
Old May 7, 2007 | 12:58 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Also be aware to go very slowly when you close the hatch for the first time with the new struts...some of the aftermarket ones can be a hair too long...one of our members replaced his and, not thinking about it, just closed the hatch...turned out the struts were like 1/4" too long and kaboom..shattered his hatch glass...he couldn't tell they were too long with the hatch open...
Old May 7, 2007 | 01:58 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
FYI: make sure you can move the piston in the cyl before you leave the store.... 1x1 cut to hold the hatch up, screwdriver remove and replace... easy job... replace both to make even when closing... and close slow and gently to get the piston moving...
good luck
Old May 7, 2007 | 02:39 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What if I just wear a helmet instead?
Where are all of you getting yours? I'd like some quality ones that last even half as long as the 23 yr old originals that still sort of work.
Autozone has some on the shelf, not sure what brand/price.
Rockauto has Monroe $25, Sachs $25, and ACDelco (left) $40
Is the right side discontinued? Why do the non oem brands have only one p/n, not different ones for each side?
Old May 7, 2007 | 09:01 AM
mikey whipreck's Avatar
mikey whipreck
MightyLift. Not sure of the lifespan compared to the originals, but they've been perfect for a little over a year for my '85. I think they were $20 each.
Old May 7, 2007 | 09:53 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
No defroster, me thinks ...
Old May 7, 2007 | 10:21 AM
Goldcylon's Avatar
Goldcylon
Super easy and a 5 min per side job. A suggestion. If you dont have a person to help hold the hatch up while you replace them you will need a wooden prop 2/4 (Dowell) broomstick or whatever to allow you to change them out. That darn hatch is heavy!! It makes the job that much easier. Place a small hand towel on top of your prop so you dont damage any of the rear defroster grids. Be careful when disconnecting each of the defroster leads on both sides as they are snug and folks that have really pulled hard can pull of the melded leads to the rear grid. So like good lovin go slow
Lastly you will be impressed on the replacements. It will be a night and day change. Dont forget the cold one at the end of the process.
Old May 7, 2007 | 10:30 AM
CentralCoaster
Does your defroster still work?
Old May 7, 2007 | 10:37 AM
mikey whipreck
My (MightyLift) autozone ones had defroster hookups on them. I can't say for sure whether they worked or not as my '85 doesn't have a rear defroster. The defroster hookups were also removeable, and I took them off.
Old May 7, 2007 | 11:16 AM
Goldcylon's Avatar
Goldcylon
Yes but I never have to use it in Arizona. I bought my replacements from MADVET. May have paid more than At autozone or Checker but I knew they would fit and work. Which they do
To Rear Hatch struts
